tunnel carpet
Old 05-22-2007, 09:27 AM
riverway
riverway's Avatar
Default tunnel carpet
Does anyone else have this problem and if so what was your fix for it. The carpet on the tunnel on the passenger side of my very early built2005 coupe continues to come loose right where the carpet joins the console. The dealer replaced the carpet on the passenger side but same problem persists. The carpet on the tunnel is too short and it contines to come loose from the console area and it looks like hell. Any suggestions?
Tim
Old 05-22-2007, 09:33 AM
cthusker
cthusker's Avatar
If you can get the carpet under the console you can probably use the high tack spray carpet glue. Just be careful using the stuff. Mask anything close to where you use the stuff. It's actually easy to work with. We glued down the carpet in some of our big rigs and it's NEVER moved... It might be better than trying to install another new carpet.....
Quick Reply: tunnel carpet
