2008 cold air intake
Cruising
can someone give me advice on a cold air intake does it really boost hp and save on gas? and can someone suggest a brand? i have a 2008 thx alot
Check this forum vendors site.
http://www.corvettec5.com/store/?pag...64db6d7fe837f0
Former Vendor
Mr Secret,
Please check this out:
http://public.fotki.com/ttschwing/co...air-install-a/
Thanks,
Carlos
If you are insterested, the Halltech Killer Bee and Vette-Air combo is on sale now!!!
Vararam won't work on a 2008, neither will the Honker, or any of the other air cleaner housings currently on the market for the older C6s. The 2008 MAF is in the air bridge, same as a Z06, instead of being a separate piece that follows the air bridge as in older C6s.
But you can add a fresh air scoop to the stock setup, see the VetteAire product, or do one of the zero $ shroud venting mods. That's all you need to get ambient air to the filter. The stock 2008 air filter has a much larger surface area than the pair used in the older C6s (not that flow restriction was ever a problem with the older style air cleaner elements either). So no need to replace the air filter housing, just add a direct path for ambient air to reach the filter.
I agree with Myhardtop and Shopdog, try the Vette-Air system Myhardtop sells either by itself or in combination with the Halltech Killer Bee. If you don't want to pay for the Killer Bee just stick with the stock LS3 intake and add the Vette-Air inlet. The stock LS3 intake is based on the Z06 intake and is so much better than the stock LS2 intake. It also has a different type of MAF sensor than the LS2 intake and the MAF sensor is built into the air bridge.
I recently added the Vette-Air inlet system and the Halltech Venom to my LS2. My buddy Modshack added the Vette-Air system to his LS3, then added a Halltech Killer Bee. The pictures Myhardtop linked to are Modshacks.
Here are a couple more of the Vette-Air inlet.
LS2 intake for comparison
Vette-Air/Halltech Venom Intake for the LS2. (Uses the same filter as the Killer Bee for the LS3/Z06)
Would love the Bee, but hard to justify the $$$$.
Supporting Vendor
Any other thoughts on the fit for the 08 from anyone???
Steve
Former Vendor
That's right!
The Vette-Air is on sale now for only $124.95 (reg price $139.95), the scoop will give your vette a big breath of cooler air.
The Vette-Air is made from a three part fiberglass material that WILL not get flimsy from heating and cooling cycles, and it shields heat from the radiator. It is light and strong...it will last for as long as you own your car and it mounts high behind the front mesh...water ingestion is not an issue unless you drive into a deep (2ft or more) puddle of water.
Please visit: www.vette-air.com
Thanks,
Carlos
Thanks,
Carlos
That's right!
Thanks,
Carlos
Thanks,
Carlos
Actually, the way your product works, it would have no effect at all on the cars ability to ingest water.
Not many choices for the LS3 yet.
Since you have an 08 I would try just the Vette-Air system first before spending more money on an intake. The 08 already has a much better intake stock than the 05-07s did. If you still want more I would consider the Halltech. Modshack just installed both on his 08, but he had the Vette-Air on a few days before the Killer Bee arrived and noticed a difference with just the Vette-Air.
The Z06/LS3 K&N has a better design for their air bridge(IMO), is much cheaper than the Bee, and fits the LS3. $270 and then just cut your shroud for free. There are plenty of dyno sheets that show significant gains from the K&N.
Also there are cheaper duct pieces that can hold up to the pressure/heat at HomeDepot/Lowes.
Remember the price is not always directly related to value or performance.
I tried installing a Zo6 CAI on a 08 LS3 and it does not fit right. It runs into the radiator support and deflects it up and the hood won't close right.
I did notice a difference after installing them. Of course it has been hot here ever since so I expect to see a bigger difference when it cools down some. I also noticed that my exhaust is louder which indicates to me that more air is flowing (I have a stock exhaust). Also based on some of the temp measurements Modshock took the airbox area is cooler with the Vette-Air system than it was before.
Since you have an 08 I would try just the Vette-Air system first before spending more money on an intake. The 08 already has a much better intake stock than the 05-07s did. If you still want more I would consider the Halltech. Modshack just installed both on his 08, but he had the Vette-Air on a few days before the Kille Bee arrived and noticed a difference with just the Vette-Air.
