08 Key Fob switch pic's
I finally got mine all complete. The fob & the key. It didn't go as smooth as every one else's that have posted.
I have a 07 Z06. Everyone said that the 07's will work with the new key. Well, when you put the 07 key up to the 08 key blank, the 07 key is wider at the tip. I had my local Chevy dealer cut the key for me using the 07 key as a template, not a vin #. He was very sceptical that it would work because of the noticeable difference in key width.
He ran the machine over it 4 times per side to insure the best cut. He even assembled the key to the fob for me. Let me tell you, you don't want to drop that screw! It is so small you would find a long lost contact lens before you found that baby!
I tried it in the trunk cylinder and it DID NOT work! I knew it was too good to be true. On my way home I was thinking of my options and remembered that the glove box has a lock. I tried that and it worked! There is hope! I disassembled the key and reversed it in the holder and tried it again, it worked! Not well but it opened the trunk every time! If this was to be a key that started and unlocked my car on a daily basis, I'd be screwed! Luckily for me, it is an EMERGENCY key to unlock my car if and only if the battery is dead. I seriously doubt I will ever take it out of the fob again.
I like the size of the new fob. The key is no longer sticking me in my pocket while I drive. I added the "remove before flight" ribbon just because I had one laying around.
As far as programing the new fob, I did the long process (30 minutes) so that this new one would be sourced as #1. It is explained very well in the owners manual and worked as described.
I am posting this to let others that may be on the fence, know it is not as cut and dry as I have read. My key almost did not work. It works now but not well. Again it is an EMERGENCY key. There is no other use for it. I could recylinder it, but in my last three years of C6 ownership (2005 C6 & 2007 Z06) I have never used the key.
For those of you who want to blast this thread for over kill, save your words. I read every thread I could find on this and no one ever mentioned any problems. Well, there is always one! And that was me!
Fob's:
Gene's comments sent to me today, and he is probably correct:
"The key was cut improperly then. Many mistakes can be made cutting keys. I have cut several hundred keys over the last couple of years and that is common when it is traced improperly. It is not how many times you trace it, it is how it is setup to begin with."
Just trying to give you "fair & balanced" reporting!
Fob's:
My dealer cut my keys from the 07 key as well, I took a piece of sandpaper cleaned up the cut a bit and my key works as good as the 07 key, like butter. You may want to try the same.
Edit: Works much better....still not as smooth as the 07 key, but this will do. As long as it will open my hatch if & when I have a dead battery, then it is fine. Thanks for the advice.
No, not out of the box. The 2007 was supposed to be the first year with the new integrated key fob. The introduction was delayed due to durability issues with the new style fob. As a result, the lock cylinder in the back was all ready changed for the start of the model year.
In order to use the new fob for the 2005 you would need to order the new fob, the new key blank along with a new lock cylinder for the back. The new key is shorter than our's and cannot be cut for use in our locks.
2008 Key
Thanks for the posting. I went to a lock smith this afternoon and asked whether he could cut the new blank for me. I mentioned that from what I've read on this forum, some people have been able to get a dealer to cut the key and others were able to get a regular lock smith to do it due to the fact that the new blank isn't as wide as the regular key. He looked at it and agreed that it wasn't as wide and said he didn't want to take a chance and cut my $37 key wrong. He then refered me to another lock smith. I was tempted to go to a Chevy dealer but even then wondered whether they could propperly cut the key. One mistake and I'd have to spend another $37. I've been following all the postings about the new FOBs and keys and can't get a feel if where the majority of members are getting their keys cut.
Good thread. I think I'll give it a try.
cut depth?
My key was cut by the vin# and it didn't work. :-( Does anyone know if the Cut Depth #1 is a true issue?
I seem to have cut depth #1 on my original key which the new key does not do. I'm still tmepeted to get another blank key and try again by tracing it.
I took jdurhan's advice and used some sandpaper on it and that made it work a lot better.
As far as the tumblers go, I have no idea. My key was simply traced at the dealer.
I think if I were to do this over, I would buy the key portion only. I would then have it cut and see if it works to my satisfaction. If it does, then I would go ahead and purchase the rest of the fob. The fob programming is pretty cut & dry. I have not read of any problems as far as that goes. That way it is only $40 to see if it works for you. Just a thought.
St. Jude Donor '06-'07-'08-'09-'10-'11-12-'13-'14-'15-'16
Sure it could be done if you have fabricating skills and the right equipment. The last thing I tapped was a keg and my old girlfriend in college.
Tapping little screw holes is definitely out of my league.
Very nice write-up BTW. This could very well be my next project on the Vette. I love a challenging project.
