Tinting rear window dot matrix ??????
St. Jude Donor '08
I have heard people talking about putting black vinyl on the dot matrix area of the rear window and they say it is great.....my question is how much of it do you cover with the black vinyl??? from my experience mostly the tint doesnt stick well to the dot matrix closer to the top of the rear window.....I was looking at the rear of a 2008 and the dot matrix comes down quite low....anyone with this tint set up care to tell me their experience with it??? rear visibility issues????? Much appreciated...i want my 2008 to come out great and not be disappointed with it....i had relatively good luck with my 2003 and 2007 tinting over the dot matrix with minimal clouding in the center near the top of the rear window
Eric aka MountinBear
My guy did the black vinyl on all the dots, so it curves down. From the outside, you can't tell it has any vinyl (at least with 20% tint) it looks just like the black edges that are already on the glass. From the inside looking behind with the rearview mirror, you can barely see the bottom edge of the vinyl (maybe a 1/4" or so). The roof pilar hangs down so low it blocks the view anyway.
St. Jude Donor '08
This is the answer I was hoping for...and since I am 6'2" i might not even see the little bit of black vinyl....thanks a bunch!!!
Mark the bottom edge of the dots with some masking tape, then take a look. I'm 5'9" and can't see it much.
Edit: Go a little below the line where the dots begin, they put the vinyl on last and overlap the tint by about 1/8". You'll see a curved line for the window defroster, they go a little lower than that first line.
