Tire pressure drop in cold weather
The low tire pressure warning indicator on my '05 vette came on recently when I started the car after it had been sitting ouside for about a week. Outside temp was in the low 30s. After driving for about a mile the indictor went out on its own. Indictated pressure in the tires was in the 23-25 psi range. I understand that pressure drops with temp, and I am not about to add more air to the tires, but I am posting this note to see if others in colder climates have had the same experience. It certainly was a suprising occurance since this is my first experience with TPM on any vehicle.
But you should add more air to the tires if the temps are going to be anywhere near that temp for awhile.
I'd be reluctant to drive more than a few days on any tires that start out cold below 27-28 lbs.
I have to add 2-3 lbs every 3-4 weeks as the temps drop here to stay. I usually add 7-8 lbs before the winter is over.
St. Jude Donor '08
....that's normal for them to drop that much....just add some air on a cold day when the tires are cold and you'll be good for the winter....
Moderator
Received 3,578 Likes
St. Jude Donor '06-'07-'09
Definitely keep the pressure at the recommended cold temperature...30#. Low to mid twenties is not safe.
Some suggest increasing the pressure to 34#/35# for an unheated, garaged car during the winter months to keep the tires from flat-spotting.
I try to drive the BlueCoupe at least weekly, and I really work on heating up the rear tires in particular. No flat spots yet!
1 Post
St. Jude Donor '08-'09
You don't have a lot of volume in those tires, so when cold weather arrives, pressures will plummet. Prepare yourself for spring when you'll experience the opposite effect.
Tire pressure is not a set it and forget it item. You will need to adjust each time temps rise and fall in extreme. You will lose or gain pressure at a rate of approximately 1 pound for each 10 degree change in temperature. You should adjust to 30 psi when it changes.
how timely
Just added 4 psi to each tire about 2 days ago. They were all at 28 psi and I figured it's only getting colder so set all to 32.
Probably add some more in a couple weeks too. It's not a coincidence that all 4 are low at the same time...
Happens here in MN by late October, depending on the temps. I always add several pounds at the first sign of them dropping and then fill them with 40# for storage. The car becomes a handful to drive on cold tires also-can get you in trouble if not careful.
Because I drive my C5 everyday, even in the winter, I get to see the pressure change a lot from winter to summer. I have driven mine is as cold as -10F and as hot as 105F. What I do is check the tire pressure on the DIC first thing in the morning (once I've driven a few hundred feet that is) and make sure that all the pressures are at 30psi. So once it gets colder out, I end up having to add more pressure obviously, and once spring arrives, I end up taking out pressure every few weeks until it gets to the hottest part of the summer. When I'm aiming for 30psi, I keep in mind if the temperature at that point in time is roughly around the average for that time of year. I've gotten nice even tread wear by aiming for 30psi on my DIC, so whether or not that PSI is 100% accurate doesn't matter to me, as I know that this practice has served me well.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
In case you think that everyone who's posted above with their recommendation to inflate your tires before you start out, and to at least the recommended tire pressure is wrong, ask TireRack. It's a free call, they're unbiased (if anything, they'd sell more tires if your tires wear out faster, which they will if you leave them underinflated----but then again, they won't sell more tires because you won't be around to buy any), and they will explain it to you.
Let me repeat, if you drive with tires severely under- or over-inflated, you will have a bad experience. And that will, at the very least, take out your car. At the worst, it will take one of us out, as well as yourself. If you don't worry about yourself, consider the rest of us, and do us the favor of inflating your tires, and watching them carefully, like once a week.
Thanks.
