Possible NAV bug...can yas confirm?
Old 12-22-2007, 12:02 AM
vettetax
vettetax's Avatar
Default Possible NAV bug...can yas confirm?
Was messing around with the voice recognition NAV commands in my '08 Coupe this evening. I state "Screen Off," the voice responds "screen off" and the screen blackens as expected. I then state, "Night Mode On," the voice responds "Screen Night Mode On" but the screen remains black.
A simple touch of the NAV hard button and the screen appears.
Am just curious if anyone can replicate. Thanks.
Dan
PS. Please no "If you build it, he will come" flames. Thanks.
Old 12-22-2007, 12:05 AM
SpankUU
SpankUU's Avatar
I got to start messing with mine. I didn't know it talks back.
Old 12-22-2007, 12:51 AM
dgrant3830
dgrant3830's Avatar
Wounded Warrior Escort '11
I don't think its a bug, rather they simply left out a command to turn it back on with voice. Day, Night or Auto mode will still do its job but a screen off overrides...I think...this is all I found:
Screen Commands
Screen Day Mode, Day Mode On: These
commands will adjust the system’s screen setting
to the day mode.
Screen Night Mode, Night Mode On: These
to the night mode.
Screen Auto Mode, Auto Mode On: These
to auto mode.
Screen Off: This command will turn the system’s
screen display off.
Old 12-22-2007, 01:48 AM
kwickag
kwickag's Avatar
There is no command to turn the screen on. If you think about it, you have to hit the voice commannd button anyway so hitting the nav button is actually shorter since you don't have to say anything.
Old 12-22-2007, 07:32 AM
FortMorganAl
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Ooops! Looks like Denso forgot a command. Screen Off turns the screen off but they didn't include Screen On. The first time I tried that command I thought I'd broken the Nav for good.
Old 12-22-2007, 08:59 AM
talon90
Support Corvetteforum!
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Dan
Confirmed on my car. I thought that the "Map" voice command would turn it back on but it does not. There is no voice command to turn the screen back on. The Nav is still active in the background and all you've done is told it to turn the screen off. Once you stated Night Mode on, it worked...you just couldn't see it. The only option is to hit the Nav hard button to display the screen again.
To Possible NAV bug...can yas confirm?
Quick Reply: Possible NAV bug...can yas confirm?
