Rubber pad for the clutch pedal?
I do not like the metal embossed clutch pedal. I usually wear gym shoes when driving, and the rubber soles stick to the pedal when shifting. I like to let the clutch slide up my foot when shifting. If I wear dress shoes with a smooth sole its not a problem.
Anyway, anynone know of a rubber cover that fits the C6 clutch.
thanks
thanks
thanks
thanks
http://www.gmaccessorieszone.com/index.php?id=133&tx_gmshopb2b_pi1[division_name]=Chevrolet&tx_gmshopb2b_pi1[vehicle_name]=Corvette&tx_gmshopb2b_pi1[year]=2008&tx_gmshopb2b_pi1[sub_product_group]=Pedal%20Cover&tx_gmshopb2b_pi1[type]=gm
Ouch the Corvette tax strike's again, $250.00 for the set.
Anybody know of a rubber pad that will fit over the clutch pedal. I went to Auto Zone, but nothing matched.
making my own clutch pad
I like to wear light shoes in summer and find that the 4 raised circles on the clutch gets to the bottom of my foot if driving for several days on a road trip. I would also like to have the pedal 3/4 inch higher than other pedals. I have assembled all the components to make my own cover. I have not done this as the car is in storage and it is too damn cold in Canada right now to work on the car. The components are a brass plate, 4 sides of brass, rubber cut from a new sandle. I intend to drill 4 holes in the brass plate to allow the four raised circles on the clutch pedal to fit into the plate, solder the sides on the brass plate to keep the rubber from sliding and then secure the unit through the 4 holes in the clutch. I will paint the brass to match the existing pedals.
I will post pictures in spring if anyone is interested
Regards,
Rich Farr
Regards,
Rich Farr
thanks
thanks
you have to brush it on and it does wear away, but it helps with grip on the pedals without changing their height or costing big bucks.
