radar detector
radar detector
where do you wire in your radar detectors. just bought 1st corvette o5 c6 and will more than likely be asking a lot of questions.so far i have gotten very good advice.thanks
I had the same question and a forum member was kind enough to post the following link . It is the best I have so far found.
http://www.bugmanweb.com/c6/c6index.html
Contact invisicord, Mine is wired via 2 pins into my rearview mirror.
http://www.invisicord.com/index.html
PHOTOSHOP SPECIALIST
http://www.vettemods.com/radarbracket-c6.htm
"Invisicord" 12 inch cord:
http://www.invisicord.com/order.html
As posted the Invisicord by CF member Teamspeed is a great product IF the detector you buy has a modular telephone jack type of power connector. If not just follow Bugman's photos and instruction to tap into the power supply on the back of your rearview mirror and do you own improvisation.
I'll add another vote for the Invisicord. I also use a Great lakes trophy mounting bracket and couldn't be happier.
http://www.greatlakestrophies.com/
I made my own using a phone cord I cut and soldered pins on. The invisicord site shows you which wires to slide the pins into. No problems with mine. Have fun.
St. Jude Donor '06-'07-'08-'09-'10,'14
St. Jude Donor '09
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
-David
Need some help...
I'm getting a Rocky Mountain rmr8rds in the mail in the next few days.I have been thinking of installing the main unit in the ashtray or in it's place.Whin the door is shut it's out of sight.{it's the remote detector-jammer}Any good ideas?
Aaron
Aaron
