Ok was under car today putting on new rims and I see what looks like air ducts for the rear brakes? I thought they were only on Z06? Where do they draw air from?
Just in front of the rear wheelwells there is a hole coming from the underneath. Just like the opening for the standard C6 in the front bumper, it looks the same for the rear.
Look underneath between the rear of the door and the front of the rear wheelwell.
Look under the car just in front of the rear tires. You will see the rear ducts that pick up air for the rear brakes.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13,'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
NCM Lifetime Member
As an aside, it is relatively easy to install the Z06 ducts on the front brakes (the Z06 design brings air up to the rotor instead of just into the wheel ell like the Z51 design). And it is a cheap mod ... ($20, max).
