alignment specs.
alignment specs.
anyone have the alignment specs for a 08 coupe with Z51 to keep the tires from wearing out so quick i don't track my car and would like to get more miles out of my tires
the tires wear on the inside edge so without a alignment change harder tires will do the same just take a little longer some one said set it close to 0 just would like to be sure before i have it done
This discussion should help you:
http://forums.corvetteforum.com/show....php?t=1882417
There are more if you want them. Do a search or let me know.
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
I'm not sure I would set it to 0. I think you could get away with a very conservative 0 toe front and rear and -.25 camber front and rear with around 8* caster. I would bet at that alignment setting you will get very long life and even wear from the tires. At 0 camber I would be worried about wearing off the outside edges prematurely.
