Chop, Cut, Rebuild, Update II
Moderator
Received 3,578 Likes
Here are some suspension shots of the Pfadt coilovers:
By the way, the bushings on the A Arms are now poly
Thanks to DTE Powertrain
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Lotta work happening.
Somba master
What are you gonna do with the fiberglass leaf springs?
I'm thinking they would make a keen longbow.....
GM
GM
Moderator
Roger that - be assured that when I get the car, results will be posted. I will be able to wring it out a little on the way home from BG on the Tail of the Dragon. Hopefully without rain!
Moderator
I'm not a suspension expert enough to know a difference. I would bet that you could call Phil at DTE or Aaron Pfadt at Pfadt Engineering and get more info than you want to know. What I do know is that this is what they recommended and the end result is less slop in the suspension than with rubber bushings.
St. Jude Donor '15
"In honor of jpee"
It's been too long ago, but I kinda remember using delrin bushings and if I recall, they were prone to squeaking. Good material and handled well, but annoying.
