Option code MM6, MN6
Old 04-12-2008, 10:16 AM
YeeeeeHaw
YeeeeeHaw's Avatar
Default Option code MM6, MN6
I have both on my option list, what's the difference?
MM6 - 6-SPEED MANUAL TRANSMISSION
MN6 - TRANSMISSION, 6-SPEED MANUAL
Old 04-12-2008, 10:19 AM
talon90
Support Corvetteforum!
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
One is the standard manual transmission for 2005-2007 (MM6) the other is the 2008- standard manual transmission (MN6)
Old 04-12-2008, 10:23 AM
YeeeeeHaw
YeeeeeHaw's Avatar
Originally Posted by talon90
One is the standard manual transmission, one is the optional transmission with the gearing for the Z51 package.
So I have the Z51 gearing? Which code is it, MN6?
Old 04-12-2008, 10:30 AM
talon90
talon90's Avatar
NCM Ambassador
Actually I need to make a correction to what I posted above.
The 2005-2007 6 speed manual used RPO MM6 but folks interchange MN6 with it to abbreviate Manual 6 speed. The actual RPO for the Z51 gearing is MZ6.
MN6 is the GM RPO used to list the 4T65E transmission. This is also the new standard RPO for the 2008 and 2009 manual six speed transmission.
Old 04-12-2008, 10:32 AM
YeeeeeHaw
YeeeeeHaw's Avatar
Yes, you are rigth, thanks for the correction.
I found this on another thread.
MYC
Transmission - Auto 6 Spd, HMD, 6L80
MM6
Transmission - Man 6 Spd, Tremec, 85mm, 2.66 1st, 0.50 6th, O/D
MN6
Merchandised Trans - Man 6 Spd Provisions
MX0
Merchandised Trans - Auto Provisions, O/D
MZ6
Transmission - Man 6 Spd, Tremec, 85mm, 2.97 1st, 0.57 6th, O/D
Old 04-12-2008, 10:35 AM
Mark-44
Mark-44's Avatar
Actually I need to make a correction ...
To Option code MM6, MN6
Quick Reply: Option code MM6, MN6
