View Poll Results: Do you use Rain - X?
Rain - X, I like it and use it
102
59.30%
Rain - X, Don't like it
29
16.86%
Rain - X, never used it
23
13.37%
Use another product for glass
18
10.47%
Voters: 172. You may not vote on this poll
Rain-X on Glass
Rain-X on Glass
I have used Rain-X for about 25 years.
First thing I have done to every car I have owed.
seeing who else uses it.
Anybody used another product like it that have used both.
I tried it on another car and don't like it. It makes a blinding glare on the windshield when passing under streetlights. I stopped using it after the first coat wore off.
Moderator
I've used Rain-X in the past, but I use RejeX now. RejeX lasts far longer and I just apply it to the windshield when I do the rest of the car.
Don't use, and do not use any other product other than a glass cleaner.
IMO, the best combination is one of the products above with silicon blade wipers.
I have a 4mil clear plastic protective sheet on my windshield. This is similar to, but not the same product, as the clear bras put on the painted area. Protects from chips & cracks as well as beading-up the water pretty good.
Those of you getting glare and streaking: be sure you're using a few drops of water when buffing the RainX off. It helps to remove the product better. It says this on the bottle, but most people neglect to read it.
My results with it increased substantially once I started doing that.
I don't use Rain-X because it uses an acid to microscopically etch the glass in order for the silicone to adhere.
I use either Rejex instead and/or a quick detail spray like Adam's. I also replace my wiper inserts once a year.
I used Rain-X for about 15 years but tried Rejex on the C6. Rejex seemed to cause more glare in a light mist so I went back to Rain-X. Rejex DOES last a lot longer. Rejex IS safer since you can spill it on the finish with no harm done. Rejex might even work better in heavy rain. But I prefer Rain-X on the windshield. All the other windows and mirrors have Rejex.
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
