Tire Pressure Sensor Tool
Old 06-26-2008, 04:00 PM
dvandentop
dvandentop's Avatar
ok i will be trying tomorrow
mine has 2 buttons in it but no manual on their website or that came with it
let me know the procedure thanks
Old 06-26-2008, 05:01 PM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
I've never used a VT10, but Bobz08C6 told me:
"It is a two button unit. The left button is for Schrader/Siemens TPMS's and the right button is for Lite-on/Beru/TRW/Pacific/Lear TPMS's."
Our C6 sensors (and, to my knowledge, all GM sensors) are made by Schrader. In that case you'll use the left button on your VT10.
Those sensors that require the right button are all on vehicles made by other manufacturers.
You'll put the C6 into the "learn mode" just as when you use any other tool - check out one of the videos using any other tool and, after putting the car into the learn mode, you'll use the VT10 exactly the same as you can see the other type of tool being used in the video below.
Bob
Old 06-26-2008, 05:16 PM
Ames
Ames's Avatar
On my CTS-V I put it in learn mode and let some air out of the tires. I guess I'll order one of these for the Vette and it will save me some time on the V also.
Old 06-26-2008, 05:41 PM
dvandentop
dvandentop's Avatar
sounds good guys i will let you know how it works out tomorrow when my hoosiers are mounted
Old 06-26-2008, 07:58 PM
Bobz08C6
Bobz08C6's Avatar
As BEZ06 states, just put the car in learn mode and use the LEFT button only. Push and hold for about 5 seconds until you hear a horn chirp. I got a one page instruction with mine. You could ask ATEQ to e-mail you one or I could scan mine and attach it to a post.
Old 06-26-2008, 08:21 PM
RedSSR
RedSSR's Avatar
St. Jude Donor '08
Attach it to a post if you would. I got mine today without instructions. I have 2 buttons on mine, what are they for? Does the Tx light light up when you push any of the buttons?
ATEQ VT10 is what I got.
Old 06-26-2008, 09:03 PM
dvandentop
dvandentop's Avatar
redssr i got the same thing
Old 06-27-2008, 08:56 AM
RedSSR
RedSSR's Avatar
St. Jude Donor '08
Do you get a light lit when you push any of your 2 buttons? I see an LED labeled Tx and thought that it would light up when I pushed a button.
Old 06-27-2008, 09:44 AM
dvandentop
dvandentop's Avatar
yes i get it on both, i just recived mine yesterday also
Old 06-27-2008, 09:47 AM
RedSSR
RedSSR's Avatar
St. Jude Donor '08
I put the battery in, push either button and no light. I guess I got a bad unit? I will have to contact them for a return I guess.
Old 06-27-2008, 09:49 AM
RedSSR
RedSSR's Avatar
St. Jude Donor '08
Also, if you go to your Hoosiers before they are mounted on the car, can you check to see if the unit is sensing the TPMS sensors while they are still off the car? I guess the unit should get a beep if it senses them? I got some pre owned track wheels that supposedly have the TPMS sensors installed and I just need to verify they are working.
Old 06-27-2008, 09:52 AM
Bobz08C6
Bobz08C6's Avatar
As BEZ06 states use the left button only for the Vette. Push and hold until you hear a horn chirp. The right button is for sensors used on other cars. I have the VT10 as well as it works just fine on the Corvette.
I'll scan and post the instruction sheet this evening. I'm driving my Vette to work today (although I'm retired).
Old 06-27-2008, 10:06 AM
  #33
dvandentop
dvandentop's Avatar
switch the battery around that was my problem
Old 06-27-2008, 10:07 AM
  #34
RedSSR
RedSSR's Avatar
St. Jude Donor '08
Does not work either way the battery is in. I have a call into them.
Old 06-27-2008, 10:11 AM
  #35
dvandentop
dvandentop's Avatar
you hold it down constant for a few seconds also?
Old 06-27-2008, 04:12 PM
  #36
Bobz08C6
Bobz08C6's Avatar
Here is the cover sheet I got with my ATEQ VT-10 TPMS relearn tool. The tool is such a no-brainer it doesn't really need any instructions other then wheather to use the left or right button LEFT button for our Corvettes.
Put car in learn mode, push left button for about 5 seconds until you hear a horn chirp, move to next tire. The TX led illuminates to indicate that a signal is being transmitted from the tool. Aim through the tire at the stem and NOT through the metal wheel.
Old 06-28-2008, 10:23 PM
  #37
dvandentop
dvandentop's Avatar
used it today works very easy great tool for a good price
Old 06-30-2008, 11:07 PM
  #38
dsanto
dsanto's Avatar
Just ordered one tonight, $15 shipping just like posted here.
Dennis
Old 07-01-2008, 07:19 PM
  #39
RedSSR
RedSSR's Avatar
St. Jude Donor '08
Had a bad tool. Just got the replacement tool today. They shipped me a new one as long as I provided a tracking number for the return shipment of the bad tool. I will check it out tomorrow.
Quick Reply: Tire Pressure Sensor Tool
