**NEW PRODUCT** Blow Dry Your Car and Save Your finish
St. Jude Donor '06-'07
IF YOU ARE A NON BELIEVER READ THE MEMBER REVIEWS BELOW
Order LINK
CLICK TO VIEW VIDEO
Like with all the other products I make or resell, I bring you the Air Force Master Blaster at over $90 off retail because I believe it’s an effective, quality product that I put into a “best in class standard”. You may be very happy with your leaf blower, water blade, or absorber, but you should read on.
All professional detailers will agree any time you touch you paint finish you add micro scratches that eventually lead to a dull finish. Of all the finishing steps, drying offers the most opportunity to damage the finish. In addition we all know about the dreaded drips from the many locations like tail lights and mirrors.
Personally, for years I have been using a combination of cotton, micro fibers, compressed air and leaf blowers. Leaf bowers are great and I am sure many of you use them. The problem is, not only are you blasting your car with unfiltered air that can contain all types of debris, the nozzle is a hard plastic that can easily scratch your car. In addition it’s difficult to maneuver the leaf blower just where you need it, like in the door jams, cowl, wheel wells.
I came upon the Air Force Master Blaster via a friend that uses it to dry all his vehicles by blow-drying them dry with high velocity heated air. If you think this is a winner on the car, you need to see it work on any motorcycle, ATV or even the family pet (yes all dog groomers use these to blow dry the dogs). In fact you will find tons of uses for the master blaster. I like blowing the mats clean instead of banging them against the tree, it leaves them fluffy.
I love the company that makes these, 70 yr old family business located in NY and the product is made in the USA and often described as bullet proof.
As a special I am bringing you the Air Force Master Blaster for only $309. Over $90 off the retail price. Please note this is a very high power system and requires a 110v 20amp outlet (which most garages have)
Member Swiftrider08 posted this a few days ago:
"There are always discussions on here about using a leaf blower to dry you car, your motorcyle, whatever. I wanted something deigned for the job at hand and also a dryer with heated air. I had always seen the Air Force One brand in my Harley magazines, so I finally took a look and found the Master Blaster. This thing puts out over 58,000fpm of heated air. It is amazing!
Well I bought one and it is unreal! Was deliveried Thrusday afternoon, so that evening I washed the Electra Glide and the 08 Coupe. I hate washing the bike as it is a bitch to dry and with all the chrome I have, water spots can not be avoided. Then the Vette has all these little places where water likes to hide.
The bike was dry in no time and I found water hiding in places on the Vette that I never knew was there before, other than the obvious mirrors and such. With the high velocity air, you can dry out the wheel wells, the grill opening, around all the lights, under & around the hood, all body seams, the rear exhaust panel, wheel rim lug nut openings, backside of wheels and on and on. With the heated air, you are not just moving the water, you are DRYING the car. Was all done in about 15 minutes and a towel never touched the car. The heated air works so well that by the time I was done, it was starting to get pretty darn warm holding onto the end of the hose. Went out to the garage this morning and there was dust on the car. Turned on the Master Blaster and in 2 min, spotless again."
The AirForce Master Blaster Dryer $309 / RETAIL $389
Order LINK
Air is heated 30deg above ambient and all the attchements are rubber so they can't damage your car. Comes with a 1 YEAR WARRANTY.
The AirForce Master Blaster Dryer features a total of 8 peak horsepower. Two twin fan, 4.0 Peak horsepower motors that deliver up to 58,500 feet per minute of clean, filtered, warm airflow. Two switches allow users to set the airflow and temperature at 3 different levels. Use either motor (front or rear) independently or both simultaneously for maximum power. Five different nozzles enable users to position airflow where desired and eliminate water spots.
Features Include:
8 Peak Horsepower Dryer unit on wheels with
12 foot cord
Rugged all Steel Construction
10-Foot Heavy Duty Hose
Heavy Duty Neoprene Blower
NozzleAir concentrator
Air streamer tool
Micro adaptor
Male/male adaptor
5 Piece Attachment Kit
1 YEAR WARRANTY
Construction: Sturdy All Steel
Motor: 8.0 Peak HP / Two Motors
Air Flow: 58,500 ft./min.
Fan: 2 Motors / 2 Stage Dual Fan
2 Speeds / 2 Temperatures
Amps: 18 Amps
Hose: 10ft. x 1.5 inch Commercial Strength Flexible Hose
Nozzle: Heavy Duty Neoprene Blower Nozzle
Cord: 12 ft. Heavy Duty 3 Conductor
Weight: 16 lbs.
Filter: E/Z Change Foam Filter
Attachments: Air Flare, Micro Adapter, 5/8" Blower Nozzle, Air Streamer Tool, 1-1/4 to 1-1/4 Hose Adaptor .
FEEDBACK
Pipedreams posted a thread (see below) around the 4th of July - offering a neat product:
http://forums.corvetteforum.com/show...ghlight=AC54ME
Mine was delivered Thursday last. Over the weekend we drove to two get- together's in the DFW area.
Today (Sunday) it was apparent that they Verts needed to be washed - and dried.
This was the first time I've used the 'dryer' from Pipedreams - what a product it is
Both Verts were washed and dried in less than two hours (total).
This included the engine compartments, as well as vacuuming the interior and putting the Verts into the garage and covering them
Comes mounted on wheels so you can roll it around, 12ft power cord, 10 ft air hose and accessory nozzle kit. There are 2 motors that you can turn on/off independently to regulate the amount of air flow you want.
Well, that is my review. I will never use another towel to dry a vehicle again!
I bought one and used it last weekend on both of my cars. It worked GREAT and actually made it FUN to dry your car. I was most impressed with how it removed all water from my rims/wheels. I was able to apply tire dressing and polish my wheels immediately after the wash without having water still on the tires or dripping everywhere on my rims. Now, I didnt use any of the nozzles, so I still need to experiment with those. It might be me, but the car just looked cleaner!!
http://forums.corvetteforum.com/show...ight=All+Clean
I give this product a 5 star rating *****
I got mine today so I just had to wash the wife's vette... Drying the vette was easy... And to top it off I was getting water out of places I never knew water rested in... It did a great job all over the car and the wheels as well. Now every time I wash the vettes I will blow dry them dry.... Great Product....
I just received mine today. I'm telling ya, guy's, this is a very nice tool, a major piece of garage gear ! I un-packed it while the spousal unit kind of chuckled and I took it out on the back deck and plugged it in, fired up both fans and knocked on the door to motion the spousal unit out to see this thing. She quickly grabbed it out of my hand and rolled it over to the outside patio table and comenced blowing it off
I can tell this thing is going to work reallly well drying the car's and the bike and it's made in the USA to boot
Thanks Ed
-Garry
Thanks Ed
-Garry
I bought the Master Blaster through Ed and have had it for about a month. I've used it to dry the Harleys and Z06. The heated high volume air works great. Much improved over the leaf blower - faster, easier to handle, no risk of scratching the paint and a better end result.
I'm running it on a 15 amp circuit and have had no problems by starting the second motor after the first is at full speed. Use a short heavy gauge extension cord, if you need one, to avoid a voltage drop that could affect the life of the motors.
Many thanks to Ed for making this product available at such an attractive price.
How does Noise Level compare to, say, a Vacuum?
Ditto, same question. Reason: In order to beat the sun, I have to wash my cars very early in the day. Both me and my neighbors very much dislike the whine of those gas-powered leaf blowers in the morning by all the yard maintenance crews. (If you've ever had to repeatedly listen to it, you know what I mean.) Just like with loud mufflers, I personally need (and want) to be considerate of my good neighbors. So what I'd like to know, is the sound level, say, similar to firing up a wet/dry vacuum? What causes me concern is 2 motors and the need for 20 amps. Sounds pretty serious = mixed blessing. Is it louder than, say, a vacuum? How does its volume compare to one of those GAS-Powered leaf blowers the yard maintenance crews use?
Sounds like a GREAT tool, and I'm seriously considering it. Just want to know what I'm getting myself (and my neighbors) into!
Thank you!
Thank you!
