C6 LED tail lights ***REVIEW*** Mid America Motorworks
St. Jude Donor '09
I just received my LED tail lights from midamericamotorworks.com
shown here:
http://www.mamotorworks.com/corvette-7-41-8556.html
LEDS off
LEDS (running)
LEDS on!
They insisted they were a forum sponsor so I hope my posting their product is ok.
I received the lights in a box inside a box. Packaging was ok but the inner box looked like it had taken a few spills.
The lights come as a set of 4 with markings for left and right tail lights. This is important and necessary for proper fitment.
The install is pretty straightforward, unplug the old lights and plug in the new ones. The LED lights have some sort of load equalizer or resister box attached which I will get to later.
THE LIGHTS ARE BRIGHT! The difference is dramatic as shown below.
There are two brightness levels. One for braking and one for running.
Running compared to C5 at night
I'll get one compared to a stock lighted C6
Now, the question you have all been waiting for...Do they hyperblink?
The answer is YES. They Hyperblink, hyperflash or whatever you want to call it when the turn signals are on but not with the hazards. This is a FATAL ERROR as far as LED tail lights go. Keep in mind I could have a defective set and I plan on contacting Mid America Motorworks on monday to see what can be done.
In the mean time I will try to add a resistor that will equalize the load to see if I can resolve the problem.
Now, should you buy them?
They look ok, kinda cheesy if you ask me with the orangy-red lens. I am working on a correction for this which involves transplanting my stock RED lenses to the LED housings. I will keep you all informed and I may make this a product if it works and only after I become a forum sponsor.
There is another LED set that looks similar on ebay with a clear lens. IF YOU PLAN ON TINTING BLACK, buy the ebay ones and save $100.
I think they are the tail lights we have been waiting for with a few bugs to be worked out. If you want to be the first C6 on your block with LED tail lights, this is your answer.
DISCLAIMER***I AM NOT RESPONSIBLE FOR ANYTHING***
shown here:
LEDS off
LEDS (running)
LEDS on!
St. Jude Donor '09
Hyperblink is where they flash at an increased rate. Like if you had a tail light out, all the lights on that side of the vehicle would flash at an increased speed. This is due to the load of all the lights when working properly not being present and the capacitor that controls the blink trips faster.
I just spoke with MID AMERICA and the "Hyperblink" is not a defect.
$349 is still better than $749 for the other ones on ebay. These are damn decent.
St. Jude Donor '09
Ok, after having the lights for a few days now, they have grown on me.
They look SICK on and off.
I have solved the hyper blink problem with 6 ohm 50 watt resistors.
I highly recommend these lights.
I'm the guy who designed the original LED taillights last year using the OEM housings. I couldn't get comfortable with the legal hurdles associated with selling new taillights. As far as the load resistors go, I found they get incredibly hot and couldn't figure out a decent place to mount them where they would not burn/melt something. Did you buy the basic 6 ohm ones that have a metal jacket, or something that has more heat dissipative area for easier mounting?
The heat can really build up if you have an automatic and/or in bumper to bumper traffic! Make sure it doesn't melt anything!
Let me know what I can do to help out
St. Jude Donor '09
Navy,
You are right, it does get extremely hot in that area.
It would seem that since these are DOT approved they are the answer we are looking for and you should definitely check them out!
Thanks fran! but I don't think it is wise to try to separate your OEM tail lights...ask me how i know.
I bought load resistors from Superbrightleds.com they do have a metal jacket and "fins" to dissipate the heat. They do get extremely hot however. I gorilla taped them to the fiberglass tub for the trunk and they haven't let go yet and I don't expect the trunk to melt. I don't think they get any hotter than the light bulb they are replacing.
Fiberglass is a different story than plastic, but still, I'd check up on them after a few days just to make sure!! Don't want you to have a hole in your rear fascia
St. Jude Donor '09
True, the resistors probably don't get much hotter than the light bulb that they replaced, but I mounted them "free air" to the original black plastic taillight housing using a long bolt and some nuts at the end to space the resistor far away from the housing. The bolt conducts heat VERY well and after about a week, the housing started to melt around the hole that the bolt went through.
BTW, how did you separate the tail light lens from the housing?
They are bright, I'd like to see two cars side by side, gotta buddy?
Absolutely. I appreciate the help. I mounted them to the tub so if it does melt; I'm not sure what would melt in fiberglass, resin maybe? anyways if it does melt it will be on the inside of the car. If I find that it doesn't melt after a week, I'll attach it with a screw.
Location: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
St. Jude Donor '08-'09
Holy "S" those are bright!!!! I think they look awesome, but I dont want to deal with modifying them with resistors etc.
