Clutch fluid level
Old 08-25-2008, 01:28 PM
TAL
TAL's Avatar
Default Clutch fluid level
Where should the clutch fluid level be at 'cold'? There is a MIN and MAX line in the cylinder.
My fluid level is in between the MIN and MAX levels.
If I need to add more, what is the correct fluid to use?
Old 08-25-2008, 01:32 PM
calemasters
calemasters's Avatar
You can fill it to the MAX line when cold.
It is normal for the level to drop some as the clutch linings wear, because the clutch is self adjusting.
Old 08-25-2008, 05:45 PM
TAL
TAL's Avatar
What fluid to use?
Old 08-25-2008, 05:55 PM
Scruff Vette
Scruff Vette's Avatar
Originally Posted by TAL
What fluid to use?
Owners manual says DOT 4 brake fluid.
Old 08-26-2008, 08:58 AM
calemasters
What fluid to use?
I use the GM Part No. U.S. 88958860, Super DOT-4 clutch fluid
Old 08-26-2008, 07:39 PM
Wayne O
CF Senior Member
Support Corvetteforum!
Wayne O's Avatar
What fluid to use?
My dealership parts department never seemed to have the GM brake/clutch fluid in the metal cans. I finally ordered some through Gene at www.gmpartshouse.com but I switched to Prestone DOT 4 in the mean time...works fine.
Old 08-31-2008, 11:20 PM
TAL
TAL's Avatar
I've done more research on this and I've found that the new C6s at the dealers have their clutch fluid right between the MAX & MIN level in the clutch cylinder.
If I fill it to the MAX level cold, don't I have to allow for expansion when the fluid gets hot?
However; I don't want the level to get too low and introduce air into the system.
Or am I just ?
Old 09-01-2008, 07:34 AM
0Brian@RPT
Former Vendor
Brian@RPT's Avatar
I keep mine between the min and max.
To Clutch fluid level
Quick Reply: Clutch fluid level
