Front end feels very light at highway speeds
I have noticed the front end of my 08 coupe feeling a little light at highway speeds. It requires real attention to steering to keep it steady. I'm thinking the GM full length racing spoiler is causing enough downforce on the rear to cause this or might it be alignment issues making it just feel sloppy at the front.
Anyone else have this or experience before?
Should not feel light, it should feel like its stuck to the road. There's no way the spoiler is putting that much pressure on the back end. I would agree, check tire pressure, alignment, and maybe have someone else drive it who also has a Vette, for comparison. Also these tires tend to grab grooves in the road, the kind made by heavy trucks...that may be happening.
If your tire pressures are not off, it has to be your alignment. Any slight misalignment will kill the straight line tracking of the car, especially at higher speeds.
Take it into a good alignment shop and have a four wheel alignment done. The difference should be dramatic.
As others said check your alignment but if you changed the rear aero, it will affect negatively the front...
Location: The Great Pacific Northwest...........I carry a gun cause a cops too heavy.
1 Post
Every new car I buy the first thing I always do is to have the alignment checked and in 40years I have yet to have a factory alignment that didn't need an adjustment. In fact I just had the alingment rechecked recently. Must be why my Supercar tires on my 05 Z51 are less than half worn out after 15,000 mi.
I don't know that I'd call my front end "light" but it does seem to be all over the road. Tire pressure is good and I'm going to have the alignment checked next week.... but I really think it's the just the nature of the tires. Had GYs on my C5 and switched to Michelins.....all my problems ended. Think that's what it's gonna take for the C6 too but don't know if I can get zero pressure Michelins for this car?
My '07 coupe has been rock steady up to 110mph on I-25 even with high desert cross-wind buffeting. That's as fast as I care to go, although at 110mph it still felt like it was cruising at 50mph. I never have had the alignment checked. Factory Goodyear EMTs, not Supercar, look good after 5K miles.
Received 2,487 Likes
St. Jude Donor '15
"In honor of jpee"
Another possible reason why car seems loose at speed
I had this problem with my 06 A6 F55 (with Z51 sways). The clutch packs created a slight yaw which put a slight sideward thrusting on the car if you were NOT GOING IN A PERFECTLY STRAIGHT LINE. Vettes had alot of clutch pack problems, lots of threads on them. UNLESS YOU ARE GETTING SOME UNUSUAL TIRE WEAR, THE ALIGNMENT IS PROBABLY GOOD. Clutch packs could easily be your problem, assuming all rear tires are the same circumfances. My problem was solved when they were finally changed out, GM has a three (3) complaints before changing them out, want change fluid twice. Good luck, GM = DELAY, DELAY, AND DELAY!
I don't know what's happening here, Karen, but that's certainly not my experience. Even before I had the alignment checked and corrected, it tracked well at speed. No floaty feeling. Just for kicks, use a known tire gauge and check the pressures first thing some morning and see how it compares to the instrument reading.
Thanks for your help.
Karen
