Firestone Firehawk Wide Oval RFT Tire Pressure
I own a C6 Convertible Non-Z51. I just replaced the front stock Goodyear Run-flats with the Firestone Firehawk RFT's and I usually keep 30 lbs (cold) for tire pressure. The installer of the Firestones have me at 38 lbs. Should they be 30 lbs like the Goodyears or do they need more pressure?
38 sounds high, I would stay in the area of 30-34 for optimum wear and performance. If you keep them that high you might see a lot of centerline wear along with a really harsh ride.
CI 2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '09-'10
I'm on my second set of the FS, for the fronts first set still on the back, and have been consistently running 30 psi cold front and rear with very good results. Misalignment caused the fronts to wear out early. I have found that higher pressures, especially in the rears, cause the middle of the tread to wear out prematurely.
I have the same tires with about 18000 miles on the I keep them at 30 lbs...so far the wear has been a lot better than I expected ...and much better than the goodyears,which came with the car
Thanks for the replies. My guess would have been to keep them at 30. The local tire dealer here doesn't have a clue, even though he pretends to.
I just had new Firestones installed today. They have them at 37 lbs all around. Unless someone says otherwise I will drop them to 30 tomorrow. I got just under 13,000 from the original GY Supercars.
The fronts were getting quite worn and I didn't want to fail tech inspection for my hot laps at Road Atlanta next week on the way to Bowling Green.
Jeff
Jeff
Received 2,051 Likes
St. Jude Donor '13
1. Why would any tire dealer tell someone a hot pressure??? Tires are always quoted a cold pressure.
2. The dealer who says 37 must have been thinking that was what was needed to seat the bead...37 is ridiculous cold.
2005 Beast
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
For 30 psi cold, the hot pressure will vary a lot with road temp. Here in Florida, the pavement will get up to 130 in the summer. Not so up north.
I aim for 32-34 hot. 28 cold works best for me.
But I am most interested in good wear, and don't do burnouts to "impress" the populace.
Location: Stafford VA, home of our wolf den. No house break ins to date.
Actually, I think HOT pressure is really the important pressure- after all, that's where the tire is driven.
If a tire is properly inflated to the O.E. requirement for a specific load, it will only gain approx. 4 psi when its hot.
You always check the tire pressure cold. The one thing about TPMS that is good, is the fact that if you have your tires properly inflated to 30psi cold.. and you notice after driving for a period of time that one tire is, say, at 38 psi and the rest are at 34 psi... then thats telling you that the tire is having some internal problems, like belt shift, sidewall breakdown, etc.... because its over-flexing.. generating more heat, which can lead to sudden air loss (blow out).
redrckt97 (05-01-2017)
The TPS will give an over pressure indication on your DIC, if you run any distance to heat the tires with that high a psi cold. It'll be happy with 30.
Some installers just keep putting the air in until the tire seats and don't always recheck it. Considering the stiffer sidewalls on these tires, it usually takes more than 30 lbs. to get them seated so they should be adjusting pressure once that's done. Can't think of many reasons to keep 37 lbs+ in these tires unless you want them to wear in the middle or you need a good kidney punching
Put them at 30 lbs. cold and you should be good to go.
I run all my tires at 34 cold.. sometimes they will go to 38 on a long trip but I never got a DIC warning...and I seem to get the most wear from them... this is ALL brands..
Thanks Wolfdogs,
"You always check the tire pressure cold. The one thing about TPMS that is good, is the fact that if you have your tires properly inflated to 30psi cold.. and you notice after driving for a period of time that one tire is, say, at 38 psi and the rest are at 34 psi... then that's telling you that the tire is having some internal problems, like belt shift, sidewall breakdown, etc.... because its over-flexing.. generating more heat, which can lead to sudden air loss (blow out)."
This was informative and makes sense. I've always run mine at 30 and watch them heat up to around 33/34 on a road trip. Now I'll check them periodically during the trip.
Mike
Mike
