Cigarette lighter not working
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
1st place I would start to trace the problem ~ fuse panel. You simply might have blown a fuse ~ located passenger side/under carpet against firewall.
Been there, done that (with a different vehicle). It was the fuse for me. Had a POS radar detector that shorted out the cigarette lighter socket. Try plugging in any 12V thing (like a portable air compressor). If it doesn't work in your Vette, but does work in other vehicles, you have your answer (the fuse)....
1 Post
Had the same problem with my 2005 C6 and a blown fuse was the 1st thing I found. Replaced fuse and my phone charger worked great so I next tried the lighter again and pop the fuse blew again. So a trip to the dealer was in order thinking I had some issue with load/amperage on the circuit but it ended up being the wrong lighter for the car. With this info in hand I asked if the unused lighter from my 2005 GMC Jimmy would work. The dealer told me its the same part # so I saved myself $20. So now all works as it should.
PHOTOSHOP SPECIALIST
As indicated above the aux power outlet and the cigarette lighter are in fact each on their own fuse. My mistake.
Thanks for checking that in the manual. I looked at the system schematic too quickly last night. I spotted the fuse #33 which is in line from the powerblock but missed the fact that the two outlets split off to their own fuses.
Holey SH** the great Paul made a mistake I don't believe it!!(just kidding)Keep all the great knowledge of yours comming!!
Ron
Ron
