Clear Bra Installer in Macon/Atlanta, GA?
Looking for recommendations for a good clear bra installer in the Macon or Atlanta, GA area. Already posted in regional. Hoping for some recommendations here in the 'General Forums'. Thanks
I have no recomondations . But I have seen cars with that clear brazier and I think that they look just awful.I would rather take her in once a year and have any rock chips fixed .Just my opinon.
Jim
Jim
I have posted a link below where you can find a qualified installer. If you use a certified installer you can't go wrong. I am fortunate in that I live in a fairly small town but we have a body shop that is certified and they cut their own film.
This is a big deal because they can cover anything. I have coverage on the mirrors, behind all wheels, in the opening where you put your hand to open the door, the nose and 1/3 up the hood.
You can buy the pieces but from everything I've read you may end up with the results mentioned by F40.
As for mine, you simply can't see it unless you get right up to it and then only from certain angles.
It was absolutely worth the expense.
http://solutions.3m.com/wps/portal/3...ind_Installer/
