UPF48R Ultra Guard Oil Filters Available
Premium Supporting Vendor
Hello All,
Last month GM released the UPF48R Ultra Guard oil filters and we have them in stock on a regular basis.
I sell them for $8.62 each. They do come in a case of 12, but I offer my customers to buy them in just quantities of 1 if you'd like. Since I've provided the volume discount already, I cannot discount further for multiple quantities.
If you'd like to order them you can go to the home page at www.gmpartshouse.com. Click where it says search by gm part number. Use part number 12626224 and be sure to select Chevrolet make.
The PF48 was originally used on all Z06 engines and 07 and up for all other engines. This filter provides more filtration than your standard oil filter. I found an article with just a couple of the differences. For those of you with the earlier LS2's you can use the UPF44 Ultra Guard filter.
DuraGuard
Your protection from contaminants – ACDelco Duraguard Oil Filters
Rely on Duraguard Oil Filters to:
Trap particles as small as 25 microns, insuring a clean supply of lubricating oil flow into the moving parts of your engine* (Based on an independent study.)
Provide a leak-proof connection with the double lock seal at the base of the filter shell and gasket retainer plate, so dirty oil stays away from your engine
Thermosetting adhesive seals hold the paper media in place for consistent, dependable oil filtration throughout the filter
UltraGuard
Worth its weight in gold for your engine – ACDelco Ultraguard Gold Oil Filters.
Protecting engines better than any other oil filter on the market, ACDelco Ultraguard Gold Oil Filters are built using state-of-the-art filter technology that helps them reduce engine wear by 74%.
In addition, ACDelco Ultraguard Gold Oil Filters:
Remove contaminants before they enter the engine
Boast the highest efficiency rating on the market at 98%, trapping particles as small as 8-10 microns* (Based on an independent study)
Ensure a fresh supply of oil to the bearings, rings and other moving parts
Have a Teflon-coated gasket that protects against leakage and makes them easier to install and remove
DuraGuard
UltraGuard
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
