Add Bi-mode exhaust to ANY C6 with the Exhaust Commander All-in-1 NPP retrofit kit
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
Exhaust Commander All-in-1 NPP Retrofit kit. More Control Choices! Lifetime Warranty!
ADD NPP bi-mode exhaust to ANY C6, from 2005-Up!
Hot News! Another new option for retrofitting NPP to your C6 is now available!
Exhaust Commander Elite All-in-1 NPP retrofit kit is now also available. Same great kit as this All-in-1 NPP retrofit kit, and includes the Amazing Exhaust Commander Elite controller.
Check out the video of the new Elite controller in this thread:
As with all my Corvette exhaust controllers, this retrofit kit has a LIFETIME WARRANTY!
Exhaust Commander All-in-1 NPP retrofit kit also has the exclusive feature of being able to be installed in the car WITHOUT having to drill ANY holes in your car! Why Drill into your car when you dont need to?
Now Available with the Exhaust Commander D.A.S.H. controller which allows you to control you bi-mode exhaust from your dash D.I.C. reset button. Click Here to Read All about it! Its also available with Lear Car2U universal visor control as an option!
Get the best system available and have one that remembers!
Order Here:
Exhaust Commander All-in-1 NPP bi-mode exhaust retrofit kit
OR
Exhaust Commander Elite All-in-1 NPP bi-mode exhaust retrofit kit
The All-in-1 bi-mode exhaust retrofit kit that we have been selling for years works on all C6's 2005-2013.
Its always been 100% Zero Battery drain since its inception!
With this bi-mode vacuum retrofit solution you get everything you need to control your retrofitted
bi-mode exhaust!
The Exhaust Commander Elite with rpm opening option we developed is also available available with this kit!
This NPP vacuum retrofit kit includes the wireless controller with one button keyfob remote, and all
of the necessary vacuum lines, vacuum solenoid and wiring to complete the control system installation.
It will give you full open / full closed modes and gives you the ability to switch between the modes
instantly using the supplied One button wireless remotes.
Typical install time is around 1 or 2 hours.
NO holes need to be drilled in your car when you mount the solenoid box outside of the car, and everything could be removed without a trace if you wanted to.
These systems are assembled and tested by Us, right here in the USA!
Quick install summary:
1: The engine vacuum tap used is the correct GM bi-mode vacuum port on the back of the
intake manifold, just like the 2008-20012 NPP C6, Z06 and ZR1's use. Not the brake booster or other critical
engine sensor systems. Do it right just like the GM factory does it. The GM engineers that designed the bi-mode exhaust system know the most reliable way to tap vacuum for the system is at the rear intake vacuum port.
The vacuum line is run above the tunnel plate from the engine to the
vacuum solenoid unit and then you hook up the vacuum lines to the butterfly valves on the mufflers.
2: The solenoid box is mounted outside the cabin requiring NO HOLES need to be drilled to install the system.
3: The wireless controller is located in the passenger fuse panel area just like all my innovative Exhaust Commander controllers allowing controller upgrades when they become available! The power cable is run
easily from the passenger foot well area to the rear of the car by tucking it underneath the trim panels.
4: Once everything is hooked up, Start the car and enjoy your fully operational bi-mode
exhaust system!
Exhaust Commander All-in-1 NPP retrofit kit install instructions
This is a great vacuum retrofit system for those who want to retrofit bi-mode exhaust to their C6
that didnt come with it. All you need is the Exhaust Commander All-in-1 kit and the bi-mode mufflers and you have a
functioning bi-mode exhaust.
Simple to install, and available with features that Corvette enthusiasts demand!
This kit allows you to start in either open or closed modes with a remembers last setting mode.
Always 100% Zero Battery Drain . Only $179.95 plus shipping!
Also available as control options:
Sunset Orange Creations will continue to develop new and improved, exciting products
for the Corvette enthusiast.
We are looking forward to helping you in the future with any of your bi-mode exhaust needs.
Feel free to contact us anytime with questions or custom system requirements.
Order Here:
OR
bi-mode exhaust!
exhaust system!
- Dash DIC reset button
- Car2u universal visor remote
- User selectable RPM opening when Exhaust Commander Elite version is purchased
St. Jude Donor '13
Zero Battery Drain, and available with DASH DIC or Car2U Universal Visor remote control. Also has the available option of automatic RPM opening mode available with the Exhaust Commander Elite option!.
So many choices its specifically built to your specs!
There is No Drilling Required to install this kit in your car.
Choose Exhaust Commander!
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
This is a great kit guys. Bens products are hands down the best on the market and the customer service can't be beat.
RICH
RICH
St. Jude Donor '13
How to get the vacuum cap off the back of a LS2 or LS3 manifold.
I have installed over 20 of my NPP retrofit systems personally and have popped that damn cap off so many times I have it down pat and can do it in 5 minutes or less now.
Here is the secret.: Use a small x-acto knife to score / cut through the the place where the cap twists off at. There is a little groove where you can place the blade and then score / cut the cap off. If you can get a decent score on the line or even cut through it about 1/3 to 1/2 way it will twist right off with little or no effort at all.
Hope that helps and enjoy you bi-mode exhaust!
Ben
Ben
St. Jude Donor '13
Here is a video of JB's LS3 gaining 8 HP and 8 tq using the Exhaust Commander all-in-1 NPP retrofit kit and Z06 3 inch mufflers.
JB's LS3 gaining 8 HP and 8 Tq using an Exhaust Commander all-in-1 NPP retrofit kit
Way to go JB, that thing is a monster!
Ben
Ben
St. Jude Donor '11
Ben
Ben
I installed the kit this weekend and all went well but that damn cap, it is the biggest pain in the A**. There is no room for a regular hand to get in there to remove it. We spent 2 hours messing with the cap. Your instructions need to have or give a better instruction on this instead of just saying to just twist it off. it is very miss leading!
Besides the cap issue (instructions) it is a great product.
St. Jude Donor '13
Yes the vacuum cap is a PITA, no bs about that. Instructions now say try and twist and then cut if needed.
I have been able to twist some off, and some others I had to cut off, it all depends on the car.
I am glad you got it, and you should know that you have used the CORRECT GM vacuum tap area for bi-mode exhaust.
Here are a couple of pix of the offending vacuum cap:
Glad you have your bi-mode exhaust up and running.
Ben
Ben
Get one Now! Add NPP to YOUR car!
This unit has the Zero Battery Drain remembers last setting mode built in! It will remember its last setting AND is Zero Battery drain!
Spare keyfob remote batteries included.
Also, Dash DIC reset button control and user selectable RPM opening are available as options!
Ben
Ben
It is working as designed.
St. Jude Donor '13
Glad you are enjoying being able to open and close your retrofitted bi-mode exhaust right from the dash DIC! No remotes needed.
Have fun and make some noise out there.
Ben
St. Jude Donor '13
Save Time, or Save Money.
If you want to save time, buy a set of GM 2008 NPP bi-mode mufflers.
They are a direct bolt in and don't require any modification fit your car.
Used sets run about $900-1100 and are fairly rare to come across.
New sets from a Gm dealer will vary in price depending on which dealer.
If you want to scar money the get a used set of 2006-2010 Z06 bi-mode mufflers. They ARE NOT a direct bolt in To you car becaue they hav 3 inch over axle pipes. You will need to cut the over axle pipes off you stock mufflers and hen have them welded tou the Z06 mufflers.
Used Z06 mufflers sell for between $300 and $500.
Once you have your mufflers all you need to get them functioning is Exhaust Commander All-in-1 NPP retrofit kit.
If you need additional info, let me know.
Ben
