npp exhaust fuse removal
Old 12-08-2008, 11:48 AM
09atomic
1st Gear
09atomic's Avatar
Default npp exhaust fuse removal
if I remove the fuse to keep the exhaust open at all times, will it cause the check engine light to come on or any other problems?
Old 12-08-2008, 11:55 AM
08 Vett
08 Vett's Avatar
I ran mine without the fuse for months and I did not have any problems!
ByByBMW
Support Corvetteforum!
ByByBMW's Avatar
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
I don't think so. The only effect you might see is excessive droning at around 1500 RPM. Some people like it, I don't, and that is why I got the mild-to-wild switch from pipedreams.
BigSlick
BigSlick's Avatar
you should be fine...you should also get the NPP kit from pipedreams as mentioned here...
Old 12-08-2008, 12:26 PM
TBD
TBD's Avatar
No probs...Kerbeck actually suggested it to me. They pulled it BEFORE the test drive.
Peace, out.
Old 12-08-2008, 12:29 PM
maxp
maxp's Avatar
Peace, out.
you will have no problem
Old 12-08-2008, 12:36 PM
Rednblack
Rednblack's Avatar
Spend the few dollars on the mild-to-wild switch. I found out there were times I wanted the quiet.
Old 12-08-2008, 12:38 PM
Pipedreams
Pipedreams's Avatar
St. Jude Donor '06-'07
ZERO problem except you will love the sound out your exahust now, you might want to add a switch so you can set them back to stock when needed, I developed these over 2.5 yrs ago www.nakidparts.com
Old 12-08-2008, 12:43 PM
LS3MODS
LS3MODS's Avatar
Default npp
I pulled the fuse when the headers were installed. Headers and high flow cats make the exhaust sound even better and louder. Wouldn't go back and reinstall the fuse for anything. Let the LS3 breath and be loud.
Old 12-08-2008, 02:04 PM
obxchartercaptain
obxchartercaptain's Avatar
FL Events Coordinator
And there is no better forum vendor!!!! IMHO
Old 12-08-2008, 02:32 PM
danl72
danl72's Avatar
Old 12-08-2008, 03:13 PM
LisasZR1
Lifetime NCM Member #2482
LisasZR1's Avatar
St. Jude Donor '11
I haven't had problem but the lower RPMs drone can be somewhat bothersome.
To npp exhaust fuse removal
Quick Reply: npp exhaust fuse removal
