Z51 vs F55 Supension
Old 12-22-2008, 02:41 PM
hurry88
hurry88's Avatar
Default Z51 vs F55 Supension
I see many posts about the Z51 pkg, how does it compare with the F55 magnetic selective ride control suspension? Or, is it apples and oranges, ride vs performance? Thanks in advance.
Old 12-22-2008, 02:44 PM
Daytona Bob
Daytona Bob's Avatar
St. Jude Donor '09 & '12, '14
2. Z51 vs F55 - There is no comparison. First off F55 was used in both settings and at various speeds. I noticed alot of "play" in the steering wheel of the F55 and it felt similar to a base suspension. The Steering did not inspire confidence in either mode. The F55 tour mode's ride felt like a base suspension and to lose handling performance for it was not practical.
The Z51 however has Zero play in the steering wheel and feels like a train on tracks. This is how a performance car should handle out of the box.
In conclusion I was extremely suprised how poor the F55 is compared to the Z51. In Fact prior to comparing both cars I was an F55 believer due to the "hype" I read on CF.
Read my complete Review here.
http://forums.corvetteforum.com/c6-c...6zhzcoupe.html
Old 12-22-2008, 02:45 PM
xcutter
CF Senior Member
Support Corvetteforum!
xcutter's Avatar
Not to be rude, but there is so much written on this exact subject. The last thing needed here is another thread like this. A simple search will give you enough to read on this subject that you may miss Christmas.
Old 12-22-2008, 02:47 PM
tfkrato
tfkrato's Avatar
Do a search and you'll find plenty of information on base, F55, and Z51 options.
Old 12-22-2008, 02:48 PM
SimonStern
SimonStern's Avatar
Or, try the FAQ stickied at the top of the forum:
http://forums.corvetteforum.com/c6-c...questions.html
Old 12-22-2008, 03:25 PM
Dry Heat
Dry Heat's Avatar
It HAS been talked about A LOT already. But I don't think you can answer your question through reading. I have Z51 and sometimes wish I had F55. But then, sometimes I am glad I have the Z51. Or maybe I will trade up for a Z06. Ouch, my brain hurts.
Old 12-22-2008, 03:29 PM
johnodrake
Moderator
johnodrake's Avatar
Received 3,578 Likes on 1,619 Posts
First order of business, say how you want to drive the car. That will dictate what options you should get to achieve those goals. F55 and Z51 are options to achieve different driving goals, one is not better than the other except in relation to those goals.
Old 12-22-2008, 04:28 PM
iridelow
iridelow's Avatar
OK, are you ready..... YOU CAN'T GET Z51 BADGES IF YOU HAVE THE F55 OPTION!!!!!
Tentoestobz (02-12-2016)
Old 12-22-2008, 04:31 PM
mte.smiles
mte.smiles's Avatar
Old 12-22-2008, 04:35 PM
Raazor
Goon Squad King of Battle
Raazor's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13x3- '14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Z51 just sounds cooler!
Old 12-22-2008, 04:55 PM
tjl5709
tjl5709's Avatar
1. Deside how you want to drive, and what the roads are like in your area. i.e. Primary purpose for the car.
2. Read past posts. As noted, this topic is beat to death.
3. Go to the dealer and test drive them.
You follow these, and it will allow you to make up your own mind.
Old 12-22-2008, 05:37 PM
golfbone
golfbone's Avatar
Ive had both, 2005 F55 and 2008 Z51. I preferred the Z51 for it's more traditional sports car like handling and feel. With the F55 you really need to change the sway bars and then you still don't have the shorter gear ratios which give the car with Z51 a much quicker and more cat like feel. I really prefer the Z51 set up for a sports car but if it was a daily driver I'd think twice.
Old 12-22-2008, 05:45 PM
CETA 256
CETA 256's Avatar
Not exactly correct, sir. My 09 F55 has the performance rear axle. To answer the OP, if you intend to track the car you will probably want the Z51. If primarily to drive on normal roads, the F55 will certainly meet your needs while being smoother and dealing with road imperfections better. You can't go wrong with any of the choices.
Old 12-22-2008, 06:09 PM
SimonStern
SimonStern's Avatar
Actually the performance axle is an option on any automatic equiped corvette. However in the MANUAL transmission cars, the Z51 has different gearing in the transmission itself, not the rear gear, so each of the lower 4 gears is lower than a similarly equiped base or F55 manual car. This gives a little more punch in day-to day, stop and go situations. I also like the gearing on a racetrack, but others disagree on this point.
Old 12-22-2008, 06:22 PM
mcwire
mcwire's Avatar
Try the F55 option, and switch to Z51 sway bars. I believe, that you'll like it. -- You can find plenty, on this topic, also. -- --
Old 12-22-2008, 06:45 PM
N62XS
N62XS's Avatar
Default OMG! Just use the search!
Here we go again! Where is harddrivin? Build the flame and ward off these winter storms!
Old 12-22-2008, 06:50 PM
LS WON
LS WON's Avatar
F-55 suspension is the most comfortable ride that you are going to get in a Corvette from factory as it works great on bumpy roads.
The Z-51 comes with tires that don't last long and of course the ride is more bumpier than F-55. Z-51 package comes with all of these extra coolers to take up more room in a already crowded engine bay. Different gearing too in transmission.
To Z51 vs F55 Supension
turmat
turmat's Avatar
AHHHHHHRGGGGGGG!!!!
Old 12-22-2008, 07:18 PM
GaussianMist
GaussianMist's Avatar
With the F55, you will share the same cool MSRC control as the ZR1.
ZR1 Interior Photo
Old 12-22-2008, 07:20 PM
BSE1956
BSE1956's Avatar
Originally Posted by turmat
AHHHHHHRGGGGGGG!!!!
Personally, I prefer the ZF5155 suspension. It's special order.
Quick Reply: Z51 vs F55 Supension
