carpet color code?
carpet color code?
Can someone tell me which of the codes in the code string on the sticker in the glovebox shows the carpet color? I know I have black leather (ebony?) interior but is the carpet a lighter color with that interior? Obviously the black floor mats I just got from Stratmosphere are much darker than my carpet - I'm assuming my carpet is charcoal and not black. Thanks
OK, figured out that code for interior is 191 which I thought was black. Is this code also ebony? Or, as I asked above, can the carpet be different color code than interior?
There's not a separate color code for the carpet, just the one for the interior. Here are the 4 color codes for a 2Lt or 3LT interior.
023 193 313 843
Left to right, they are red, ebony, cashmere, titanium gray.
If you have the red, ebony, or titanium gray interior, you have ebony carpet. Otherwise, you have cashmere carpet.
EDIT: I should have looked at your profile first. You have a 2005. I don't see a 191 color code in the order book. 193 is the interior color code for ebony. And no, the carpet color must agree with what I stated above. If you have the cashmere interior, you will have cashmere carpet, otherwise you have ebony carpet.
023 193 313 843
OK - thanks for the help. I got confused when I looked at another site which showed "191" as an interior code for black. I do see on my 2005 1SA a 193 code following the 191. I guess I have ebony interior and a set of non-matching Stratmosphere mats! Thanks again
