DIY Battery Relocation on a C6 *Pics Inside* (non Z06)
Old 12-27-2008, 05:53 PM
cencalc6
cencalc6's Avatar
Default DIY Battery Relocation on a C6 *Pics Inside* (non Z06)
Here are a few pics and step by step of my Battery relocation kit.
Battery: Braille B2317R
http://braillebattery.com/index.php/batteries/b2317r/
Moroso battery cable kit
http://www.jegs.com/i/Moroso/710/74005/10002/-1
This is were the fun starts remove that old heavy *** battery
comparing both batteries
There are (4) 13mm bolts inside the battery tray loosen and remove
remove from inside your fuse box the 13mm nut ,remove the cable and follow it to your starter ,this is your original possitive cable. Do the same steps for your negative cable.
put the 1 gauge gound wire together which mounts to the frame and the engine block
a little heat wrap for protection
use the same mounting bolt and location for the new ground cable
mounting the other end of the ground cable to the block, it's a 15mm bolt
Now on to the power wire, remove the rear wheel liner
Fish the 1 gauge wire thru the rocker panel
connect the possitive power cable to the starter
Original Battery 34.2 lbs
Braille Battery 17 lbs
Odyssey bracket that had to be cut down an inch
marked holes with a sharpie
Old 12-27-2008, 05:54 PM
cencalc6
cencalc6's Avatar
Original equipment
Battery = 34.2 lbs
Battery bracket = 1 lbs
Battery harness = 1 lbs
Total = 36.2 lbs
Battery Relocation Mod
Braille Battery = 17 lbs
Custom Battery Bracket = 0.8 lbs
14 feet of Cable = 5.2 lbs
terminal ends,bolts,nuts,etc = 0.7 lbs
Total = 23.7 lbs
36.2 lbs-23.7 lbs = 12.5 lbs weight reduction
need4sspeed85 (08-21-2020)
Old 12-27-2008, 06:04 PM
webdzynes
webdzynes's Avatar
wow. just one question - why?
Old 12-27-2008, 06:06 PM
VET4LES
VET4LES's Avatar
Good job. Looks like this post.
http://forums.corvetteforum.com/c6-t...tml?highlight=
Old 12-27-2008, 07:02 PM
peter pan
Life Time NCM #2196
Support Corvetteforum!
peter pan's Avatar
Received 1,096 Likes on 808 Posts
Nicely done and very good write up
Old 12-27-2008, 07:15 PM
cencalc6
cencalc6's Avatar
I'm doing a full engine bay clean up by hiding/tucking wires away, so this was my first mod and more to come Oh! btw another reason is, I did a whole Z06 conversion widebody,brakes and why not relocate the battery in the rear just like the C6 Z06 ,I get bored easly and just start ripping things apart and move things around ,thanks for the comments
Originally Posted by VET4LES
I also have the Z06,Forced induction,Parts,C6 Sales,and ZR1 section to post up thanks for the comments
Old 12-27-2008, 07:36 PM
tmjvett2009
tmjvett2009's Avatar
St. Jude Donor '09-'10-'11
Why
Old 12-27-2008, 07:42 PM
LMB-Z
LMB-Z's Avatar
Nice write up, nice pics....but WHY???
Old 12-27-2008, 08:00 PM
Joe_Planet
Joe_Planet's Avatar
why not just fabricate a new battery bracket and mount the braille where the OEM battery used to be?
this way you dont have to dick around with all that extra wiring...
Old 12-27-2008, 08:04 PM
BetterMostC6
BetterMostC6's Avatar
Originally Posted by tmjvett2004
Why
My Question exactly!
Old 12-27-2008, 09:42 PM
cencalc6
cencalc6's Avatar
Why
LMAO! with this WHY question once again fellas I am cleaning up my cluttered engine bay,thanks for the comments
the_slo_vette (11-12-2021)
Old 12-27-2008, 09:50 PM
cencalc6
cencalc6's Avatar
Now your thinking dude no disrespect but read my previous post to answer your question
Old 12-27-2008, 10:05 PM
LS2-Zomb!e
LS2-Zomb!e's Avatar
Thank you.
Old 12-27-2008, 10:15 PM
keg
keg's Avatar
A lot of work for WHY?
Old 12-27-2008, 10:29 PM
cencalc6
cencalc6's Avatar
lol! either way it's cool no hard feelings
Old 12-27-2008, 11:13 PM
Camaro4Life
Camaro4Life's Avatar
Why????!
haha, nice, keep doing these tuts if you can, I would love to see a clean engine bay.
Old 12-28-2008, 02:58 AM
spin-doktor
spin-doktor's Avatar
Whyyy ?!?!
To DIY Battery Relocation on a C6 *Pics Inside* (non Z06)
Old 12-28-2008, 07:36 AM
gota07
gota07's Avatar
Cruise-In VIII Veteran
Assuming you have a stock audio system etc. what kind of lifespan can you expect to get from the smaller braille battery?
Old 12-28-2008, 07:50 AM
NYC6
NYC6's Avatar
I guess alot of people on this forum never heard of something called weight transfer.
Great writeup and pics.
My car is in the shop now getting a Vortech installed. This is something Im going to do.
The following 2 users liked this post by NYC6:
JSracing (08-19-2020), K03 (02-16-2020)
Old 12-28-2008, 08:17 AM
RadarP3C
RadarP3C's Avatar
As far as the weight transfer issue is concerned...I think the corvette is already at 50/50 in stock form.
I believe the OP moved his battery to the rear was to clean up his engine compartment (with a little weight savings in the process) which isn't a bad idea....
My solution is to keep the battery up front and install a battery box around it.
Quick Reply: DIY Battery Relocation on a C6 *Pics Inside* (non Z06)
