Should I be concernced about "WD1 - PILOT VEHICLE"
I've been looking for a used '08 Corvette for months now. I found a good one that has a build date of 05/07/2007. Must have been one of the first '08 models, judging by the WD1 - PILOT VEHICLE code on the build sheet. Does anybody know of any problems with these early vehicles, or are they just like any other '08?
I really wouldn't be "concerned". As you suspected a WD1 is basically an early build pre-production car. It is assembled on the line and is used to develop or enhance the process for the next model year build. It is going to be just the same interms of features as any other 2008 car.
The car wasn't likely flogged nor would it have been used by anyone other than a GM employee for the time that it was in service unless anyone bought it before you. Frankly, I'd have more concern for what ever mileage was put on by the previous owner if there was one.
As little insight for you:
RPO WD1: WD1 is the IDENTIFICATION CODE FOR A FACTORY PILOT VEHICLE, for the Next Model Year. Example: If the factory was building 2007's and a "RPO WDO" & "RPO WD1" was going to be built, it would be a 2008 Model and would have a 2008 VIN Plate attached to it. Of course this would be a EARLY MODEL 2008 C6, with a build date in the middle of the 2007 Production time line, and a JOB# for the current 2008 C6 Model Production.
Corvette Enthusiast
Probably was a "Fast Feedback" (FFB) car internal to GM, what's the mileage?
The car before being auctioned to your dealer (ask them how long they have had it they should know) was updated to the latest running production software and hardware (at that time).
So while the build date is early CY 2007, the parts actually may be from mid-year (early CY 2008) depending on the time it was sold to the dealer.
This is done because there could still be software bugs in those cars after they are built that get fixed before serial production, and since you can't count that each FFB car has been updated they "clean point" them before auction.
I actually spend my day updating such FFB cars for my company who works with Chrysler.
I think with the economy the way it is, if there is any concern about buying this particular vehicle you should be able to find a good deal on another one that's not a 'pilot build'. It's a buyers market
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
No idea what to tell you. But since production didn't start on the '08s until very late June, I wonder about this car. It's definitely a pre-production car. Maybe someone else will comment on it.
Note: I guess they already did, above.:o
Pilots are built with production approved parts and probably was overlooked much closer when it was built than typical production cars. I wouildn't be concerned about it if the mileage was reasonable. For those that have posted they would move onto another 2008, would you pass up on a "Pilot" 2009 ZR1?
St. Jude Donor '15
"In honor of jpee"
Thanks for all responses so far.
It's a fully loaded 4LT 6A coupe with only 3200 miles on it. Asking price is $43,000.
Corvette Enthusiast
Anything that is a pilot doesn't contain serial production parts. Even the earliest builds (prototype production) contain "2008" or whatever year parts. They may not contain final revision of the parts, but most people would be suprised at the number or running changes that happen in a model year (the first serial production car is not identical ever to the last serial production car in a given model year).
The purpose of pilots is not only to test the in plant process but also to produce vehicles to debug. Anything that isn't serial production has a purpose, either marketing, fast feedback, specific teams (powertrain, electronics, etc). No car built before serial production is built for giggles. The sellable ones are built so late in the process they typically are used for so called "finishing touches" to the customer experience, which is why I said fast feedback, executives are complainers and make excellent mock customers.
The part I work on went thru 11 changes during 2009 development and production (this was our first model year), 3 of those are running production changes (after initial serial production), and 2 of them are between the final pre-production (S2) and serial production cars.
So all the pre-productions in our case had to be updated to at least the original serial production level (they actually got updated to one version newer that that). These things are not unique to us as a supplier, or to Chrysler. GM does the same stuff. Changes are fluid and continuous.
Hmm, why build them then?
Anything that is a pilot doesn't contain serial production parts. Even the earliest builds (prototype production) contain "2008" or whatever year parts. They may not contain final revision of the parts, but most people would be surprised at the number or running changes that happen in a model year (the first serial production car is not identical ever to the last serial production car in a given model year).
The purpose of pilots is not only to test the in plant process but also to produce vehicles to debug. Anything that isn't serial production has a purpose, either marketing, fast feedback, specific teams (powertrain, electronics, etc). No car built before serial production is built for giggles. The salable ones are built so late in the process they typically are used for so called "finishing touches" to the customer experience, which is why I said fast feedback, executives are complainers and make excellent mock customers.
I am not saying that this car was identical to the first built 2007 when it came off the line. We both agree that even the last 2007 built is not identical to the first one that came off the line.
The question was asked if the OP should be concerned about a WD1 vehicle and my answer is no, he need not be concerned. This car will come with the same warranty as any other 2008 car. It was not a flogged ZHZ rental, it will have likely have been driven by an engineer, taken home, taken away for the weekend and evaluated. When done it will be R&R'd and brought up to standards and allowed for sale or retained for long term testing and evaluation.
Really slim. While It could have a part(s) that are dimensionally different from the final buildout. Typically by this build the parts should be on production or near production tooling and processes and be fully validated. Anything that could have been one off or rare would have likely happened in an earlier build. Anything that did make it this far would (should) have been removed prior to the car being allowed for sale.
Paul
Dan,
Paul
Paul
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Don't worry about it...I have one of the first C5s built from October, 1996. VIN is a first day of production pilot build, #100098. The car was driven by GM execs for a few months then put up for sale at a local Michigan dealer. Over time I have come to realize it was pampered by Engineering, for example, no rear end leaks like so many of the later production vehicles. Buy the car and enjoy it!
