GCA (Genuine Corvette Accessory) Splash Guard installation w/ pics
Old 02-20-2009, 08:53 PM
BLACK 08
BLACK 08's Avatar
Default GCA (Genuine Corvette Accessory) Splash Guard installation w/ pics
The install is pretty simple over all. You do have to remove the rear tires but there's nothing difficult about that. Once installed they look like they came on the car. The fit is perfect and you can hardly tell they're there. Now I know some people say "mud flaps" don't belong on Vettes but these are far from "mud flaps" and don't forget they come stock on a Z06. OK now on to the install.
Here is everything ready to go.
You need these two tools to complete the install however you can just use a small screwdriver instead of the pry tool.
The drill bit is kind of an odd size and I didn't have one in my set but I picked one up at Lowes.
For the fronts you need to remove the push pins inside the wheel well.
Just pry the head up and pop them out.
This is what the push pins look like once removed.
The new push pins (on the left) are obviously larger than the stock ones but they fit with no problem.
This is what the back of the splash guard looks like. The red line is backing for the tape seal that helps secure it to the car.
Clean the edge with the alcohol pad provided.
Put the push pins in but not all the way.
You want to leave them like this until you pull the backing from the tape and stick them on.
Pull the backing off. Make sure you place it where you want it the first time because the tape sticks really well.
The directions say to push with 20-30 pounds of pressure and "iron" it on from the bottom. I have no idea how much 20-30 pounds feels like so I just pushed them on with a lot of force.
Once they are secured with the tape you can push the pins in all the way. This does take some force so push hard.
And here you go. Now just repeat on the other side. Then on to the rears.
Old 02-20-2009, 08:58 PM
Not Paid 4
Not Paid 4's Avatar
Location: You must be young and stupid before you become old and wise... Canton Georgia
Nicely done How much did you pay?
Old 02-20-2009, 09:06 PM
BLACK 08
BLACK 08's Avatar
For the rears you need to remove the tire to give yourself some room to work.
Once the tire is removed, place the splash guard in place making sure that the bottom is flush with the car. Then tape it in place with some masking tape.
Mark the holes with a marker or whatever you prefer and drill the holes.
Here they are all drilled.
Then put the push pins in but like the fronts don't put them in all the way until you secure the tape.
After the tape is secured (same as the process for the fronts) push the pins in all the way. Again they do require some force so push hard.
Just repeat for the other side and you're all done. This mod is well worth it and I think they should come on the car like this. BTW I know my car is DIRTY but don't worry it's well protected with Wolfgang 3.0 Paint Sealant from Autogeek. I drive my car ALL the time and trust me a little dirt doesn't hurt..
Old 02-20-2009, 09:07 PM
BLACK 08
BLACK 08's Avatar
$105 plus shipping
Old 02-20-2009, 09:18 PM
Just Buy It
Support Corvetteforum!
Just Buy It's Avatar
Great job and thanks. I had always thought they dont belong but after seeing some in person they do look like Z06 guards. In the end its better protection and less rock chips and road grime. I will buy and install when it breaks 50 degrees here!
Old 02-20-2009, 09:20 PM
CETA 256
CETA 256's Avatar
They look great.
Old 02-20-2009, 11:03 PM
Poppy's Vette
Poppy's Vette's Avatar
Sweet. I likey. BTW, are they the same color as our rear valance? They appear a little lighter, more gray in the pics.
Old 02-21-2009, 09:07 AM
gota07
gota07's Avatar
Cruise-In VIII Veteran
The color matches the rear valance very well. These pics are a bit misleading in that respect.
Old 02-21-2009, 09:26 AM
Walt White Coupe
Walt White Coupe's Avatar
Received 2,221 Likes on 1,139 Posts
Great post Mr. Black 08. The cars should come this way from the factory like the ZO6.
Old 02-21-2009, 09:37 AM
dvilin
dvilin's Avatar
Received 7,918 Likes on 4,804 Posts
Old 02-21-2009, 09:55 AM
BLACK 08
BLACK 08's Avatar
Exactly.. The flash from the camera makes them look more grey. I'll take some pics in the sun when the car is cleaned up to show how they look.. I am very particular about things I put on the car and if they didn't look right they would be gone.
Old 02-21-2009, 10:00 AM
Rich Mickol
Rich Mickol's Avatar
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Excellent write-up. If I didn't already have 3M on the wheel wells, I'd be buying them today.
Old 02-21-2009, 10:02 AM
jeffjob
POSSE Senior Hombre
jeffjob's Avatar
St. Jude Donor '13, '17-'18
Black 08;
Great post and thanks for taking the time to do this.
You did a great job with the photos and descriptions and I know lots of people are going to find it helpful.
Jeff...
Old 02-21-2009, 10:39 AM
Ken Fichtner
Ken Fichtner's Avatar
Cruise-in I Veteran
Cruise-in II Veteran
Cruise-In III Veteran
We have sold hundreds of sets of these and everyone loves them! Reasonably priced protection that looks great and they are really easy to install.
Forum pricing special $99 (complete set of 4)
Call Bob Wendorff in our parts department to have yours shipped today!
800-234-5284
Old 02-21-2009, 10:53 AM
BLACK 08
BLACK 08's Avatar
Originally Posted by jeffjob
Black 08;
Jeff...
Anytime..Thanks for the reply..
Brett
Old 02-21-2009, 11:19 AM
routesixtysix
routesixtysix's Avatar
Default Thanks for the Installation Pics
Very timely. Ordered mine from Bob at Fichtner last week and will install them when the weather gets a little warmer. Won't be long in North Carolina!
Old 02-21-2009, 01:44 PM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,095 Likes on 807 Posts
Nice detailed write up and looks like I need to order these as my buddies make fun of my mud flaps
To GCA (Genuine Corvette Accessory) Splash Guard installation w/ pics
Old 02-21-2009, 05:59 PM
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
Thank you all for your business and buying from the king and the highest seller of Genuine Corvette Splash Guards in the country.
This is a great how-to and should be made a sticky! Thanks to the OP for everything.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Old 02-21-2009, 06:36 PM
danl72
danl72's Avatar
Cool.
Old 02-21-2009, 06:39 PM
Red Rochester
Red Rochester's Avatar
Looks good
Quick Reply: GCA (Genuine Corvette Accessory) Splash Guard installation w/ pics
