'08 Key Fob Issue
'08 Key Fob Issue
Today I had a problem with the key fob. I have an 08 and it is not subject to the sensor recall. A search of the threads came up empty. The car did not see a fob. I was able to start the car by opening the trunk, open the door with the pull and placing the fob in the glovebox slot. I thought it was the fob battery because the 2nd fob worked fine when I got home. I opened the fob and tested the battery and it was ok. I put the battery back in, closed the fob and now it works fine. Has anyone had a similar problem and can this fob be trusted?
Sounds like it could be something as simple as cleaning the contacts. Maybe when you removed the battery and reinserted it your scraped off a small amount of corrosion that was causing the problem? Just food for thought.
If this is in fact the case, next time you take out the battery... take a #2 pencil (the old wood kind) and use the eraser on the contacts. It's like a mild sandpaper. Clean off the contacts with the eraser and then grab a Q-tip and soak it in isopropyl alcohol and then swab the contacts. Wait to dry, then re-insert the battery.
St. Jude Donor '09, '14
