Jake skull underhood liner or graphic?
I was just wondering if anyone knew where I could find a vinyl or graphic for the underhood like the corvette emblem ones but with the Jake skull. If not I am going to have one made
Cruise-In VIII Veteran
Check out Vette Stripes. They had a giveaway of some smaller Jake vinals. They also do custom items from pics you send in.
www.vettestripes.com
Airbrush may be your only option here. If you airbrush there are many things that you could do other than just a straight Jake. You might draw something up and have a local airbrush artist give you a quote on it.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
JAKE on the hoodliner
Paint the entire hoodliner, front and back, with flat black rattle-can spray
Lay out your Jake with blue low-tack painters' tape
Spray the color of your choice (I wanted a subtle dark gray)
and . . . Voila ! .
Waiting for the heads-and-cam project underway at HorsePower Sales to be completed.
and . . . Voila ! .
Location: Surgeon General never said anything about smokin' tires! Pigeon Forge, Tn.
and . . . Voila ! .
and . . . Voila ! .
That is awesome. Did you use high temp paint?
Just a detail: I also painted the four plastic push-pins that go in the dark gray area with the same dark gray paint. I used Dupli-color adhesion promoter on them first to be sure the paint would stick.
