Broken Glove Box Latch
Old 03-17-2009, 11:30 AM
CropDuster
CropDuster's Avatar
Default Broken Glove Box Latch
I went to open my glove box this morning and the latch fell off in my hand. Anyone else had this happen and know the fix/cause? My warranty just ran out in January too.
Old 03-17-2009, 11:32 AM
AORoads
AORoads's Avatar
Received 2,481 Likes on 1,944 Posts
St. Jude Donor '15
"In honor of jpee"
yes, it happens. mine was under warranty as have been a lot of CF members. I think it's a five dollar part, if that.
Old 03-17-2009, 01:07 PM
ro2516
ro2516's Avatar
I bought a used 2008 last month and the latch broke off in my hand the day the car was delivered. The "paddle" you pull with your hand snapped off from the glove compartment. Repaired under warranty.
Old 03-17-2009, 01:30 PM
CMY SIX
CMY SIX's Avatar
god I think your going to have to sell the car, I hear those latches are expensive
Old 03-17-2009, 02:25 PM
cclive
cclive's Avatar
Latch is cheap, order it and then u transfer the lock cylinder from the old to the new one. Easy. Happened on mine but under warranty. It seems like it was a late '07/early'08 problem mostly...bad batch
Old 03-17-2009, 02:41 PM
danl72
danl72's Avatar
Old 03-17-2009, 02:59 PM
cclive
cclive's Avatar
Hope yours is grey, because its less expensive than the other 3 colors..
Old 03-17-2009, 03:27 PM
metal
metal's Avatar
Exact same thing here...dealer replaced it with no problem. I think they had a bad batch of plastic
Old 03-17-2009, 05:31 PM
raider4251
raider4251's Avatar
It happened to mine with only 15 miles on it. (early 08)
Old 03-17-2009, 05:38 PM
Red Rochester
Red Rochester's Avatar
all the time
Old 06-15-2009, 08:12 PM
naschmitz
naschmitz's Avatar
My latch just broke. Ordered a new one from Gene Culley.
But how do I get the lock cylinder out of the old latch?
Old 06-15-2009, 10:40 PM
gbgary
gbgary's Avatar
you, me and at least 20,000 others. my third as been the charm.
Old 06-16-2009, 11:08 PM
nwrwy
7th Gear
nwrwy's Avatar
If you are talking about the center console,that latch is not cheap. Bought replacement from Chesrown in Ohio, they have good prices and it was almost $40.00 last year.
Old 06-16-2009, 11:19 PM
Marc V.
Marc V.'s Avatar
Old 06-17-2009, 12:28 AM
Zymurgy
Moderator
Support Corvetteforum!
Zymurgy's Avatar
Received 15,075 Likes on 6,173 Posts
Definitely NOT a five dollar part. Probably not worth more than $5, but the MSRP is between $34.67 and $54.91, depending on color. Gene's prices are between $25.69 and $40.68, again depending on color.
Yep, the gray is the cheapest, then Cashmere then both the Red and Black are the highest.
OP definitely stated glove box, not center console.
Old 06-17-2009, 05:51 AM
metal
metal's Avatar
Same, same exact thing here!
Old 08-18-2009, 09:05 AM
ATC
ATC's Avatar
Mine just broke last Friday. Early 2008. At least when the warrenty runs out, it's titanium (grey).
To Broken Glove Box Latch
Old 08-18-2009, 09:09 AM
LOUSVETTE
NCM Member
LOUSVETTE's Avatar
Real PIA. Threre is a hole at the end of the end you have to push in (real hard) with smal srcewdriver or awl. It comes out but you really ahve to fight with it
Old 08-18-2009, 09:38 AM
C6~Missle
C6~Missle's Avatar
same herre.. within a couple of weeks.. fixed it myself. wasn't worth a trip to the dealer.
Old 08-18-2009, 10:38 AM
CON ART C6
CON ART C6's Avatar
Happened to me twice, first time dealer fixed it under warrantee, second time spent 40 bux and replaced it myself. I thought i was the only one with this problem, cus im to yolked and dont no my own strenght.
Quick Reply: Broken Glove Box Latch
