Door opens and window will not Roll down..
Sometimes when i open the door the window wont crack to let the door open without hitting the window seal.. and when i go to close it it wont shut.. i have to use my window valet and roll them down then shut then roll them back up.. anybody else have this problem and how did you fix it? thanks
I don't want to offend because this is a completely legitimate question asked by many many folks, it just amazes me how many people have problems with window indexing. It literially should be on page 1 of the operating manual in large text because there are so many owners who have this happen and don't understand why or how to fix it.
Well ill say this i have had the same problems a few times even after I have indexed the window .
Ill re index the window a few times and it will go away then sometimes it will come back a few weeks later again
Dumb question. What is a Window Valet? Is it some sort of electronic device that is added to the car to roll down the windows with the keyless FOB? If so, maybe there's something with the integration of that device-hickie that is messing with the vehicle electronics or window electronics?
Other than that, I don't have a "window valet" and I have never had an issue.
Sorry to hear about your troubles. Please post when you find out the root-cause.
PHOTOSHOP SPECIALIST
Here's some info on the Window Valet:
http://www.topdowntech.com/wvc6-Documentation.html
http://www.topdowntech.com/documents/WV-110.pdf
Second thing I learned today! This forum is AWESOME!!!
Even then you may forget and think it is something you did when you fixed something on the car and they won't work. Disconnect the battery and you'll find out, especially if you have the windows down and you own a vert.
