GPS and Window Tinting
Hello all!
I just recently purchased a new 2009 Corvette Coupe with the navagation system. I have a few questions for you out there.
According to the "Navagation System Manual" (page 2-60) it says:
"Notice: Do not apply after-market glass tinting to the vehicles windows. Glass tinting interferes with the systems's ability to receive GPS signalsand causes the system to malfunction. The window might have to be replaced to correct the problem. This would not be covered by warranty."
After doing some other research on the internet it would appear that metallic window tint films attenuates the GPS signal. (Or reflects it maybe?)
***Updated*** (Bad wording on my part.)
If this is the case then my next reaction would be to use the new ceramic films. However, it would appear that none of the local window tinters carry the product, and I have been told that they cannot fit the ceramic film to the curve of the back glass. Other types of films can be.(Or, so I have been told.)
Questions:
(1) Where is the GPS attenna located? (Other posts suggest it is located behind the left center AC vent on the center of the dash.)
***Update***
I just read the manual some more. Looks like that antenna might be located around the rear shelf; "This system may not be available or interference may occur if any of the following are true: "Objects are located on the rear shelf of the vehicle.""
(2) Has anyone had any problems with tinting thier windows with metalic films and thier GPS units?
The accessories person at the Dealership claims he has had no problems with it. Only the Malibu seems to be affected with the FM antenna...
I was not planning on tinting the front winshield at all. I just wanted the doors, and back glass.
Anyones comments are greatly appreciated.
Thanks!
(First post by the way. Glad I found the site!)
***Update***
I found a place locally that will use the ceramic tint! 15% here I come!)
Questions:
***Update***
Thanks!
***Update***
St. Jude Donor '09-'10-'11
When I had my 2009 vert done they refused to put a strip at the top of the frond windshield because they said it would mess up the nav
You want to use a color stable non-reflective film.
Personally I would choose Solargard Supreme. Not HP Supreme as the HP has metal. Just NR Supreme. I am not a big fan of Llumar or 3M, but they also make comparable products.
A windshield strip will not interfere with Antenna using an NR Color Stable product. Also the Vette is a tough cookie to tint so make sure you seek out a reputable good tinter. The tint will lay down over the dots without turning white in the rear if he's good. Black paint, vinyl, or "it will dry" are not acceptable.
I recently had my vette windows tinted and since I don't have Nav they said I could use the metallic tint. With Nav they don't recommend metallic because it does interfere on some vehicles. As for being able to do the back window in one piece, a knowledgeable tinter can do it whether it's metallic tint or not without a problem.
If the OEM unit is that picky then I'm glad I went with Garmin.
As far as the rear window talk to your local Corvette Club. I'm sure they will have a few recommendations. The ones in your areas sound like newbies.
What if you just decided to scratch the whole tint idea. I know I'm in the minority but I've never really cared for a tinted window past what comes from the factory.
That has ran across my mind. But, I just gotta have the windows tinted. I like the "look" it provides....
As usual, there is a lot of misinformation in this thread.
Metallic tint will NOT affect the factory NAV as long as you don’t tint the front windshield.
As mentioned, the antenna is under the dash so as long as it can receive the signal down through the front glass you could put whatever you want on the side and rear.
I have Llumar metallic on the sides and rear and my factory NAV works just fine.
My Z06 has ceramic window tint, but not on the windshield. Plus, the body panels are composite, your GPS navigation should be able to get signals from other directions.
http://advancedfilmfl.net/2008/01/07...erference.aspx
However, I would like you to read the 2009 Corvette Navagation System Manual on Page 2-60. I think the GPS antenna is located on the back glass.
"This system may not be available or interferences may occur if any of the following are true."
* Objects are located on the rear shelf of the vehicle
* After-market glass tinting has been applied to the vehicle's rear windshield.
This makes me think it is located on the back glass, but the dealership claims it is on the front dash.
I dunno.
I'll keep everyone advised of my experience.
I have been told by two different window tint installers that that kind of tint will not fit to the curve of the back glass. Your statement here make me think they are lying to me, or trying to sell me the standard window film.
Grrr....
I posted this thread as a fact-finding mission. I am very glad to hear that you are having no issues. I think that I am just going to have the windows tinted and risk it.
