SAHS with a twist
Ok, in summation as far as installing the clip referenced in TSB 06-02-35-002B.
1. Remove the trim panel under drivers side dash (2 torx and clips)
2. Remove 2nd panel under drivers side dash (clips only, just tug gently, it comes out)
3. Remove connector at steering wheel position sensor.
4. Attach clip from TSB
5. Put everything back together.
Connector that you will install clip to:
Connector with clip installed:
Connector plugged back into SWPS:
Sorry the pix aren't focused perfectly, but it's sort of a no-brainer once you get the right wire.
