Do you add any gas treatment?
Old 06-03-2009, 11:43 AM
KWC6
KWC6's Avatar
Default Do you add any gas treatment?
I have an 08', 22,000 miles. Do you add any gas treatment occassionaly, meaning fuel injector cleaners, sulfur deposit cleaners, stuff like that? All I have done so far is premium and Chevron, BP gas as much as possible.
Old 06-03-2009, 11:49 AM
runutzzzzz
Support Corvetteforum!
runutzzzzz's Avatar
I use BG 44k every 20K or so. Even tho I use top tier, it makes me feel better
Old 06-03-2009, 11:50 AM
LMB-C6
LMB-C6's Avatar
Just as a preventative measure, I run through a tank of gas treated with 1 bottle of Techron before I change the oil at the end of the season.
Old 06-03-2009, 11:57 AM
danl72
danl72's Avatar
I do not use anything. I use 91 and I have not had any issues.
Old 06-03-2009, 12:05 PM
cclive
cclive's Avatar
I buy Techron at Costco for $15 per six pack. It costs $6 a bottle at Walmart. I put a bottle in about every 3000 miles, usually before a long trip. Its very little money for the piece of mind.
Old 06-03-2009, 12:14 PM
lander
lander's Avatar
St. Jude Donor '09-'10-'11
Beano
Old 06-03-2009, 01:56 PM
dvilin
dvilin's Avatar
Received 7,926 Likes on 4,810 Posts
Nope, I use 91 or 93 octane and that seems to be fine, no need in my opinion for any additives.
Old 06-03-2009, 02:07 PM
harrower
harrower's Avatar
Keeps the fuel sending unit clean in the tank. Sure cheaper than replacing the fuel sending unit. Good price at Costco. I'll check that out!
Old 06-03-2009, 02:31 PM
FloydSummerOf68
FloydSummerOf68's Avatar
BG 44K, without a doubt, is the king-daddy of fuel additives.
I do a seafoam treatment every ~15K miles or so. 1 can in the gas tank, 1/2 can in the crank case, and you can use the other 1/2 can through a vacuum line to clean out the top of the motor.
Old 06-03-2009, 02:47 PM
B-STOCK
B-STOCK's Avatar
St. Jude Donor '14-'15, '17, '19
I do the same.
Old 06-03-2009, 03:23 PM
bsr8129
bsr8129's Avatar
nope
Old 06-08-2009, 07:06 AM
AvalancheGuy
AvalancheGuy's Avatar
Default Just ran some TECHRON through...what a difference!
I've learned a lot from you folks here on the forum! My DD was running like poop...ping, clink in the engine on acceleration..and I ALWAYS run 93 octane from Hess or Gulf (sorry..no Chevrons up here). I ran a concentrated tank of TECHRON through the Hemi... now she purrs.
Think I'll put a can through the Vette as preventative maintainance...piece of mind thing.
Old 06-08-2009, 08:42 AM
KENZ51
KENZ51's Avatar
I think I need to do this myself, Ive noticed that there seems to be a slight hesitation on acceleration. I have put in additives in the past, but its been awhile. 67,000 miles.. I may need to get new injectors.
Old 06-08-2009, 08:50 AM
calemasters
calemasters's Avatar
At every oil change:
Old 06-08-2009, 09:09 AM
vetdude
vetdude's Avatar
...made by Techron. The new fuels all have detergent additives in them to keep the injectors, valves, etc. clean so using an additive is just a waste of money. But, if you must and have money to burn, either a bottle of Techron Fuel System Concentrate Plus (not the Techron "Fuel Injector Cleaner" sold at Costco for cheap), GM Fuel System Treatment Plus (same product) or a can of Sea Foam are best to give you that warm fuzzy.
PS: the older C5s had the fuel sending unit problem that was corrected on the later models and subsequently the C6s.
Old 06-08-2009, 09:42 AM
JRHAWK9
JRHAWK9's Avatar
yep, I use something recommended by a well known Tribologist in tune to 1oz per 10gal in every tank.
Old 06-08-2009, 10:34 AM
Gordon Shumway
Gordon Shumway's Avatar
The only difference between this and Techron Fuel System Cleaner is price. A 20oz. bottle of Techron is $10, and the same GM bottle is $26 (at a dealer). The GM bottle even has the Chevron logo and patent # molded into the bottom of the bottle.
To Do you add any gas treatment?
Old 06-08-2009, 10:47 AM
GOLD72
GOLD72's Avatar
Received 1,106 Likes on 718 Posts
Generally yes. I tried AMSOIL PI at 30k miles and saw a 1 to 1-1/2 mpg increase in fuel economy within a couple of thousand miles. Seems to meet the claims that AMSOIL makes for it. Techron never made that kind of difference for me previously.
Old 06-08-2009, 10:53 AM
LS WON
LS WON's Avatar
Chevron used to sell at their gas stations a bottle black in color with gold print and it was for the engine deposits and other stuff. It wasn't the same as the fuel injector Chevron cleaner and cost alot more for one bottle of this stuff?
Is this still around?
Old 06-08-2009, 10:54 AM
LS WON
LS WON's Avatar
Same here.
Quick Reply: Do you add any gas treatment?
