Looking at buying tunning software...
Hi Actually this a question on buying a 2009 camaro ss ,and I heard if you tune the ecu, the warranty is voided... Is this true? I heard they can see if programed it before even if it was returned to stock settings before bringing it back in for whatever reason to the dealership? Is the new vett like this too? I heard there also was a tamper seal is it on the obd2 port or the ecu? I just swap ecu if I had to.
St. Jude Donor '08-'09-'10-'11-'12
Returning it to a stock tune does not eliminate the recorded history of what has been done as I understand it.
I can't answer the tamper seal question but I have not heard of one.
Can't answer the warrenty question but if you want to research different tuning software options go to ls1tech.com. they have tons of info on the various tunning software out there. Lots of choices.
Go over to corvettemechanic.com/forum/ and click on C6 technical info. There is a post on "GM's crackdown on aftermarket calibrations". Apparently a good tech can tell if the ECM was reflashed or replaced. There are inconsistencies that a trained tech can pick up. The additional 10 -15 hp gain is not worth voiding the powertrain warranty. Those who install headers, intake, cam, etc. will need a tune to gain maximum performance.
