Smaller Steering Wheel?
I have an 09 C6. Are the D-shape steering wheels any smaller? What about the Z06 wheel? Finally, anyone know of a vendor that sells steering wheel spacers, to bring the wheel closer to the driver? I have a 1LT car, so no telescoping wheel, and I am basically about an inch away from reaching the top of the steering wheel comfortably when everything else is adjusted correctly. Other than that, the car is awesome.
Thanks.
Thanks.
St. Jude Donor '14-'15, '17, '19
I have been looking for a spacer too. I have the tele wheel and it only mover about 1 1/3 inch. My C5 moves almost 4". I will be watching this thread in hopes of getting a spacer.
All wheels = same size!
As for smaller wheels: There´s a guy here in Germany who fits any RAID wheel into your car -don´t know about spacers but if you want I can ask him...
All the wheels that you mentioned are the same size...in fact, they are all the same wheel. The D shaped wheel is just an OEM wheel that has been covered in leather. I have a D shaped wheel for my 2005 and it was an OEM wheel modified. For what it is worth, the 2005 wheel is actually a larger diameter than the 2006-2010 wheel.
I'm all ears
Cmon bro, I got a lt1 and I am only 5 7' ...what are you under 5 feet?
You gotta work the seat adjustment and keep playin with it and the steering wheel ...it will work. I couldnt find the magic either but I kept trying and I found it... No spacer crap..
I don't recall the exact diameter change...It is somewhere around 1/2"-1" I think.
I assume this was directed towards me. I am about 5-9 or so, and I don't think my reach is that bad. I think my overhand driving style may be to blame. I have lowered the steering wheel as low as I can and my leg hits it uncomfortably when I go for the brake. I really only find it to be an issue when I am trying to row the gears with my right hand and steer with the left hand on the top center of the wheel. I just don't feel as though I have complete control with just my left if I am driving at speed. I suppose I have to play with it some more, the car is still new. A smaller wheel would be ideal though, I could lower it a little more than I can now and it will also make the steering feel a bit heavier, which is something that would also be desirable to me.
