Curb weight includes what amount of fuel in the tank?
What amount of fuel in the gas tank does curb weight account for? With a gallon weighing roughly 8 lbs the car can weigh quite a lot more or less depending on what level the tank is assumed to be at. About 144 pounds heavier with the tank full than empty.
I would presume that curb weight includes all fluids normally carried on-board: fuel, oil, coolant, windshield washer, power steering, transmission, and differential. It should not include a driver, passenger, or rated cargo.
Published "Curb Weight" is at best a guess, at worst just another advertizing gimmick. Every option changes the weight of the car, there is no one curb weight for a C6.
If you really want to know the weight of the car, take it to a specialist alignment shop and have it "Corner Weighted".
My '08 Coupe was 3266#'s with aprx 6 gallons of gas (all other fluids full) so aprx 3230#'s for my '08 3LT, A6, Z51, Nav. Maybe subract a few pounds for books, Manuals, tools, etc.
My '05 Coupe was 3251#'s with aprx 3 gallons of gas (all other fluids full) so aprx 3236#'s for an '05 3lt, M6, Z51, Nav. Maybe subtract a few more pounds since I had more tools in the ''05.
What was interesting was the Front to rear distribution; The '05 M6 was 53% F, 47% R, the '08 A6 was 51% F, 49% R.
gasoline is about 5.93-6.42 lbs per gallon,depending on type/temp diesel is about 8lbs per.....
You could go to your local track, the ones in STL have the scale you drive on for your vehicle weight with driver then simply subtract yourself.
Moderator
Received 3,570 Likes
Water is 8 lbs/gal. Gas is about 6 lbs/gal
According to Dan Maslic in his book "Master EFI Tuner" regular grade gas weighs 6.25 lbs per gal @ 72* and Premium grade weighs 6.35 lbs per gal at the same temp. ( Yea, I know, BFD)
BJK
BJK
My understanding is that curb weight was with 4 gals of gas. Don't have anything to back up that statement, just my failing memory.
edit: doing a google, every source said that the curb weight included a full tank of fuel.
Curb weight is the weight of the vehicle full of fluids but without driver, passenger, or any cargo.
Rule of thumb
Gas weighs about 6lbs btw.... http://wiki.answers.com/Q/How_much_d...gasoline_weigh
BTW you can use for Gasoline: 6 #/gal, for Oil: 7 #/gal and for water: 8 #/gal. Those are the values we used to use back in the day for calculating take off weights when I was flying. Those are the single easy to remember digits and close enough to not get into trouble trying to take off with a too heavy airplane.
Depends on the temperature and altitude
