Tire Pump
Tire Pump
Sorry, I know this has been covered in the past. I'm about to take a long trip and want to get a portable tire pump to take along. Can anyone suggest a good brand which is fairly compact, good quality and pumps fairly fast? Thanks very much.
CF Senior Member
I have a small Craftsman compressor/air pump that works well. It's compact and stows easily in the rear storage cubby. They have re-chargeable models or ones that you plug into a power source. It's not as fast as using a compressed air can but it's considerably smaller and it doesn't run out of air.
Supporting Vendor
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
I have one of those 12v jumper/air pump units from Sam's. It works pretty well on my other vehicles I used it on although the Vette has not needed it. I like the idea of carrying air and portable power in which ever vehicle I'm in.
I got a small one at WalMart for $9.99. It is very compact and I have used it once out in the middle of the desert and it worked fine. The actual compressor part of these things is fairly standard, most of the difference is in the case that surrounds it.
I would suggest buying a tire plug kit at the same time. You never know when you are going to have to plug the tire to keep the air in until you can get it fixed! I bought one with two installing tools & glue for $20. at an Auto Zone! Better safe than sorry!
Dan
Dan
I got one of these Corvette kits. Haven't used it but it has everything you need for $45.00.
http://www.motopumps.com/
I have gone through quite a few tire pumps and found that the most important thing is not the compressor itself but how it connects to the tire. Fancy compressors with gauges and such are not neccessarily better. I have bought fairly expensive compressors that come with plastic fittings that screw on or go over the tire. These are junk. Try to find a compressor that has a metal fitting that attaches to the tire.
The best I had was a cheap compressor with a metal fitting that went over the tire with a metal clamp on the back to tighten it. It also had an air fitting on the back to check the pressure while you were filling it.
One caution... these are designed for motorcycle tires, and after inflating the (huge) tires on the 4x4, the pump was HOT! I only got it about 1/2 inflated before I had to shut down the pump and let it cool. Probably won't be a problem with the Vettes and the low profile tires though.
If You're Going To Buy A 12-Volt Air Compressor, Make Sure It's A Nice One
http://www.griotsgarage.com/product/...+compressor.do
I just bought the slime kit at Target for $19.95, it has a 300 psi compressor and the metal connector.. fits perfect in one of the back storage pockets. Have a plug kit as well..
http://www.slime.com/product/122/Sma...S-PDQ/06).html
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Good caution, however, I found this on their website essentially saying it won't damage TPMS.
http://www.slime.com/faq.html#answer_1431
St. Jude Donor '09
Found a digital craftsman on sale for like 15-20. Set the built in gauge for the pressure you want and it shuts off when the pressure is attained. Pretty neat little deal and fits in the storage compartment in the back.
Retired & lovin' it!
I carry their pump & a plug kit I got at a local auto parts store. If I remember correctly, the pump alone was only $20 or $25. Haven't had to use it since 05 & hope I never will, but cheap insurance.
Did anyone notice the part that says will not damage is actually in smaller font than the rest of the page. Its almost like they don't want people to see it or aren't 100% sure. One would think they would want it to be larger font or even in bold.
