Do I have to fill my tires with nitrogen since the dealer had nitrogen in it?
Old 08-19-2009, 03:59 PM
buffguy
buffguy's Avatar
Default Do I have to fill my tires with nitrogen since the dealer had nitrogen in it?
or should I be fine with regular air?
Old 08-19-2009, 04:00 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
Don't waste your money messing with the nitrogen.
Old 08-19-2009, 04:01 PM
ByByBMW
Support Corvetteforum!
ByByBMW's Avatar
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Well, air is about 80% Nitrogen so I think you will be okay.
Old 08-19-2009, 04:29 PM
inthehunt2
inthehunt2's Avatar
Unless you plan on racing it and are concerned aboiut reducing your pressure change by 2 psi, then don't worry about it. Use regular air. It's free and it won't make a darned bit of difference unless you're racing it. And by racing I mean road course racing with extended time where you're running flat-out and really working the tires in the turns.
Old 08-19-2009, 04:31 PM
BAMF AE
BAMF AE's Avatar
Location: The Surgeon General has warned that it's ok to smoke mustangs!
St. Jude Donor '06-'07
I seriously doubt you drive "nascar" style on a daily basis to warrant using nitrogen in your tires....besides....it's really anyways. Don't fall into the "ohhh I've got Nitrogen in my tires" crowd.
Old 08-19-2009, 05:05 PM
Piratesoul
Piratesoul's Avatar
You will be fine with regular air. I actually sell the Nitrogen generator / inlfators to dealerships.
And no I don't have Nitrogen in my tires.
Old 08-19-2009, 05:23 PM
Vinnie T
Vinnie T's Avatar
Regular air is fine, but nitrogen is nice if you want a more stable air pressure in your tires. Not all that necessary for street driving. Nitrogen doesn't seep out as fast as oxygenated air and isn't affected by temperature as much either. Regular air = about - 1 lb./month for seepage and approx. +/- 1 lb. per 10* of temperature change. Full nitorgen will better that by at least 50%. That's not
Old 08-19-2009, 05:46 PM
3GenVettes
3GenVettes's Avatar
Although regular air is fine, the nitrogen is unquestionable more stable with regard to tire pressure. It also does not seep out as easily. The benefits of being nitrogen filled diminish as you over time replace with air. But free is a pretty good price for air.
Old 08-19-2009, 06:06 PM
-CM-
-CM-'s Avatar
http://blogs.consumerreports.org/car...nitrogen-.html
Old 08-19-2009, 06:24 PM
cmonkey713
cmonkey713's Avatar
Received 1,251 Likes on 916 Posts
No problem with adding atmospheric air to your nitrogen filled tires.
Old 08-19-2009, 07:46 PM
07 Z51
07 Z51's Avatar
I've always wondered: If you use helium in the tires, will the car be lighter?
Old 08-19-2009, 08:17 PM
Glen1224
Glen1224's Avatar
Location: Lower Macungie Township ; Commonwealth of Pennsylvania
OMG now he has me wondering
Oh I know the answer : not lighter but, your tire noise will be a lot higher pitch and the tires will be flat in the morning like a ballon
Old 08-19-2009, 08:20 PM
iridelow
iridelow's Avatar
It's just another "gimick" used to sell cars or tires! Kind of like the $500 scothgaurd protection dealers used to put on your seat. It was a $10 can of scothgaurd spay! It's a big bag of
Old 08-19-2009, 08:47 PM
Slogo
Slogo's Avatar
No, your wallet will be lighter.
Old 08-19-2009, 09:04 PM
OhNiner
OhNiner's Avatar
In my current C6 the dealer filled them for me and the psi was 30, a few months later and the psi is now 28.
Seems to leak as bad as regular old air.
Old 08-19-2009, 09:53 PM
BigJoe
BigJoe's Avatar
If that were true and the oxygen seeped out first, after a few refills you would have nearly pure nitrogen. The only difference between air and pure nitrogen is that air normally has water vapor in it. Dry air works the same in all respects as dry nitrogen.
Old 08-19-2009, 10:04 PM
tolnep
tolnep's Avatar
out of curiosity, i went to look at the new 370z at a local nissan dealer..
car had the 'blue' caps on the valve stems and a 300$ charge added to the sticker for this most precious of gases...
a relative bought a car bout 3 years ago. had the blue valves. he goes to get his oil changed and one of the local chains.. ask them to check/fill his tires (which needed btw) and they said.. no way we cant touch them blue valves!
scam scam scam..
i think it started in aircraft tires, cause of the heat when they hit the runway landing, nitrogen wont expand so much, less potential to pop a tire landing, racers picked up up looking for the tenth of a second difference (and i suppose it does make a difference here) finally the dealers picked it up to replace scotchguard, pin-stripping and undercoating..
To Do I have to fill my tires with nitrogen since the dealer had nitrogen in it?
Old 08-19-2009, 10:05 PM
obxchartercaptain
obxchartercaptain's Avatar
FL Events Coordinator
Problem is...all you get at the dealer is HOT AIR...
Old 08-19-2009, 10:12 PM
BartonekDragRacing
BartonekDragRacing's Avatar
figures... all the nitrogen haters start comin out of the woodworks. Just like us Z-51 Vette ballers.. peeps be hatin' on us.
Old 08-19-2009, 10:48 PM
Divvi
Divvi's Avatar
Where can I get a 'Nitrogen' Badge???
Quick Reply: Do I have to fill my tires with nitrogen since the dealer had nitrogen in it?
