Lear Car2U visor compatible NPP Exhaust Commander is HERE! No Fobs! 5 min install!
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
Lear Car2U visor Compatible Exhaust Commander is HERE! Get yours now! This controller works with your Car2U Universal visor remote!
Introducing the new Lear Car2U visor compatible Exhaust Commander
One Button Wireless NPP/Z06/ZR1 exhaust controller!
For sale in my online store and ready to Command your NPP, Z06 or ZR1 Bi-mode
Exhaust from one button on your 2006-2010 Lear Car2U universal visor remote! No Fobs Needed!
I offered the first version of my Exhaust Commander One Button
wireless NPP/Z06/ZR1 exhaust controller unit for sale 2 years ago. Now
here is the Lear Car2U visor compatible Exhaust Commander unit!
You get the 2006-2010 Lear Car2U visor compatible Exhaust
Commander main unit, and install instructions in PDF file format on a
CD. You can also have a keyfob remote added as an option if you want to
control the exhasut from outside the car.
Take Command of you NPP, Z06 and ZR1 exhaust, you get to choose
whether the exhaust is Quiet and mellow, and you also get to
Command it to be Loud and mean when you want it.
Open and close your exhaust with ONE button on your Lear Car2U
visor or with an optional One button Keyfob remote. Switch between
Quiet and Loud anytime at the push of a button!
You press the button on the Car2U visor or keyfob remote once, the
valves in the bi-mode mufflers close and you have the quiet factory
operation mode, nice and quiet and opening at the factory rpm, press
the button again, the valves open and you are in Loud mode and ready
to rumble! Exhaust Commander is 100% Zero Battery Drain when the
car is turned off.
Its a Simple 5 minute plug and play install! No permanent modification
is made to your car, it can be removed without a trace in 5 minutes.
Purchase Price is $149.95
Click Here to buy one--> Lear Car2U Compatible Exhaust Commander
Get your 2006-2010 Lear Car2U universal visor compatible Exhaust Commander One Button
Wireless NPP/Z06/ZR1 Exhaust Controller now!
Take Command of your NPP or Z06 Bi-Mode Exhaust!
Every unit is tested by me personally to ensure perfect operation and they are
backed by a 100% Lifetime Warranty!
I am completing the kits now and will be shipping them in the the order
the purchases come in.
Ben
Click Here -> Exhaust Commander D.A.S.H. the revolutionary new bi-mode exhaust controller!
NPP Bi-mode exhaust vacuum retrofit kits -> Exhaust Commander All-in-1 bi-mode retrofit kit.
Clean Your Wheels Easily -> PowerStick Wheel Cleaner
My Online Store -> See all my Bi-mode Exhaust Controller Products!
car is turned off.
Ben
St. Jude Donor '13
Step 1: Fold down the passenger footwell carpet to reveal the fuse panel area.
Step 2:Pull the two fuses that the arrows are pointing to.
In the photo the fuses are already pulled out.
Step 3: Install the fuse adapter as shown in the top fuse slot.
Install the exhaust fuse signal wire into the left side of the exhaust fuse slot as shown,
and tie down the ground ring under the 7mm bolt on the amplifier as shown.
Step 4: Place the main unit underneath the amplifier.
Step 5: Use the supplied unique code to sync the Lear Car2U visor to the main unit.
Step 6:Fold the passenger footwell carpet back into place.
You are all done!
St. Jude Donor '13
Thank you everyone for your orders and support!
FREE Shipping on all orders in September for the Exhaust Commander and Sunset Orange Creations 2 Year Forum anniversary.
Also a FREE $10 Chevron / Texaco gas card with every order in September!
Get yours now!
Ben
Get yours now!
Ben
St. Jude Donor '13
Have a Safe and Great Labor Day Weekend!
If you need any info, let me know.
Ben
Ben
I have the original one and it works great! Controlling the switch from the visor is the easiest application... The remote control is great for "out of the car" parking lot demonstrations.
St. Jude Donor '13
Its great for those who dont want to look for a remote while driving and just want to use the universal visor thats built right into your car!
Ben
St. Jude Donor '13
Zero Battery Drain valves start closed - when the car is started it will be in the factory operation mode and will open at the factory rpm.
Zero Battery Drain valves start open - when you start the car the valves will stay in the loud / open position.
After startup you can then open and close the butterflies using the Lear Car2U universal visor remote. No keyfob remtoes are needed, just the visor.
When the butterflies are in the closed position they operate exactly like they did from the factory. When you choose Loud / Open mode they are open until you choose to close them.
Uopn the startup of the car they will revert to the startup option you have chosen.
There is available as an option a small keyfob remote that can be used outside the car to open and close the butteflies while at carshows or for just showing off outside the car.
Ben
