z51 or z06 sway bar
#41
345 rear with a hallway bar
The stiffer the bar is in the back, the sooner the back will break loose in a corner, so the bigger Z06 bar is designed to work right with the bigger rear tires of the Z06. With the rear tires of the regular C6, the bigger bar will make the car tailhappy; the rear will be wanting to break loose and come around first. The front bars are the same size, Z06 and Z51.
As is so often the case, more is not always better.
