Sic Motorsports Z06 Fascia Install or Andy Gets a Nose Job
So, I'm not missing my Corvette enough, my buddy Andy says "Why dont you come over and help me install my new Z06 fascia???"
A beautiful day...no car to drive...oh well, might as well help my friend out...haven't played with a Vette in a few weeks and since Andy's is identical to my old car (they were even built 2 days apart), why not add some jealousy to a beautiful day???
In case you haven't seen it yet, forum vendor, Sic Motorsports has made a Z06 nose fascia that works on the stock C6 front WITHOUT having to change the fenders as well.
All in all a very nice piece, well made, fit nicely and color match/paint quality was excellent...and that's coming from a picky detailer like me. If I had to knock something, it was that the instructions were sparse to non-existent....no pictures, basically 8 lines of instructions with no pictures, tip hints, etc. Though the change was easy enough for someone comfortable with tearing the panels off a car (...something we've done a FEW times... ), I think it would be intimidating for a Saturday mechanic without more detailed step by step instructions.
In all fairness, we had to contact Daniel form Sic Motorsports with a question or two, and he called us back immediately, even though it was a Sunday afternoon...GREAT service. I imagine the instructions will be updated soon, so do not let that stop you if you are interested in the piece. It looks great, it's reasonable, and will make your car stand out. It goes great on Andy's car since he also has the rear widebody conversion.
Well, enough of my banter, here are the pics:
Up in the air, ready for the transplant
Stripped and prepped
Grills installed and ready - still waiting to receive the C6 nose emblem
Installed
Looking sharp, even though it's been a year since the last Craigsterizing...full detail to come this week....Hey, I gotta earn my Seafood Dinner....
Installed
looks awesome, great job. Did the grill/screens come with it? If not where did u buy them? Thanks.
Grills came with the bumper. The center Z06 grill was purchased from vendor and shipped with bumper. The vendor supplies metal grills for the center opening and lower vents. I chose to have a different look. Either way they both fit without a problem.
I’ve been contemplating doing this mod cuz I like the built-in splitter look, but one thing keeps jumping out at me when I see before and after pics. Now I’ve never actually seen the Z06 front bumper on the standard C6 in real life so it may just be a visual effect of the pics.
When viewing this conversion head-on it appears that the smooth flow from the bumper under the headlight around to the front fender transition is “broken” when the Z06 front bumper is adapted to the standard C6. Like the bumper has to wrap back in to meet the narrower fender of the standard C6.
Does it look like that in the flesh?
It looks GREAT! But how are you going to keep from destroying the bottom of it? I have a standard Z06 nose and the plastic on the bottom gets beaten on a regular basis...and I am really carefull.
Looks super, nice job.
The wrap-around doesn’t appear to have the same smooth “flow” when viewed head-on after the SIC Z06 bumper is installed. Looks like the side “indents” to meet the fender. Maybe it’s an optical illusion.
Don’t get me wrong, I'm not knocking the car…it looks great …but that “indented” look kind of bugs me if that’s actually the case in real life.
Hard to describe but I can always post a photo if you like.
The bumper itself is flexible. Prior to install it was twisting and bending without a problem. The bottom tray and foam holds it in place. A hard hit to a parking lot stop would most likely damage the bottom tray. The bumper itself can bend alot.
I realize that the SIC Z06/C6 bumper is specifically designed to fit the standard (non-Z06) C6, but how was it redesigned? Did they just remold the outer edge to transition “back” to the standard C6 fender or did they reduce the entire width of the bumper.
When I was researching it myself I was wondering about as well. But the new nose is the same dimension width wise as the c6 bumper. All the holes and tabs line up as if the original was put back on. The difference is the front grill and lowering of the front bumper to the lower tray. The " indents " your talking about aren't there. The photo's don't do it justice. From the side you think the original bumper was in place. If you go to sic motorsports website he has a few more photo's of other vehicle's to look at. I'm pretty picky regarding body fit and finish and I have no problem with it. Craigster05 details cars and knows and see things I couldn't even see and was amazed on the fit and finish. Drop him a pm and he can explain better.
Straight-on side view with that new bumper looks trick.
The head-on view always throws me off for some reason…glad to hear I’m not really seeing what I think I'm seeing.
So far I haven't had any issues with bumps or going up driveways. The bumper sits above the level of the previous vertical part of the skirt underneath. You'll need to be careful pulling up to curbs or other parking obstructions. I believe it no less of a problem as before. The new bumper just extends the lower portion of the flat part of the skirt.
The bumper would hold up but the bottom support tray would break. I don't plan on even coming close to one.
If you look underneath the front bumper on a c6 you'll see it sloops down to a point and then stops. The new bumper is at that level from the front already.
