Gas Treatment during Winter storage
How do forum members treat their fuel during winter storage or during longer than normal periods that their Vette is in "storage." Is there any fuel stabilizer that is recommended or considered best for use.
Sta-bil is the way to go. I use it on everything from weedeaters, lawnmowers, waverunners, all the way up to my cars. I've also always been told to fill the tank to the top to avoid condensation when the temp drops, but that may be more important on a daily driver than the stored vette. If the tank isn't full, I would fill up ASAP come spring to dilute the old gas.
Sta-bil has worked well for me too. Just a note. C5s and C6s have 2 tanks. So what I've done is add the Sta-bil during the last fill-up and then drive it straight home and park it. I would guess that if you add the Sta-bil after you've parked it, you'll only get it in one of the tanks.
- Mark
- Mark
St. Jude Donor '13-'14-'15-'16-'17
Stabil
I used to think it was snake oil, but after a few carburetor cleanings on my bike due to stuck floats, I now use it in every engine that sits idle for a few months in the winter. Haven't had a stuck float since.
LJ
LJ
Fuel...
I have been told by different folks that know a lot more about fuel than me that there is no need to add Stabil or whatever to the fuel when you car is only going to be parked for 6 months. They have said todays fuels at the pump are so good additives are just not needed anymore when only a few months are involved... Then on the other hand the additives are so cheap if it makes you feel better then go for it...
StaBil. At the end of November I go through about a gallon of it. I add the amount needed for a full tank and drive three blocks to the service station and fill up. That way it is well mixed in the tank.
I do this for three motorcycles, three Corvettes, a Viper, a 4x4 truck, a gas powered generator, a riding mower, a lawn mower and a snow blower which is done in the spring.
I have done this for years and they all start up immediately after as much as 6 months standing. The ones that have batteries have tenders hooked up also.
For many years, I have seen the consequences of other people not using Sta-Bil in their engines (from lawn mowers to race cars) – so I always use it in the vehicles I store for four months or more. I have never had a problem.
I added Stabil as well last year, and when I started up after the winter I had the Check Engine Light come on... went out again after filling it up the first time after emptying the tank with the Stabil added.
Am I the only one that experienced this?
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Received 8,928 Likes
The owner's manual for my John Deere lawn tractor says to use a product like Sta-Bil with every fill up due to the tractor sitting a week or so between being used. So if they recommend it for storage periods of a week or two it may be necessary in a car when storing for more than a couple of months.
Bill
Bill
Yes - doubt it was related to Stabil. More likely related to loose gas cap.
Do to all the gas reformulating and most pumps giving out that 10% ethanol crap the survivability of gas has went way down.
From what my own experiences show and knowing a lot of mechanics at the many marinas and equipment stores in my area, the consensus of opinion is to either run dry a fuel system or put in Stable. (Most say use Stable)
That is for ANYTHING (gas powered, as Diesels use different fuel and additives) that is going to sit more than 3 months.
I have quite a few seasonal toys, equipment and vehicles and I follow close the 3 month rule!
I just make sure the tank is full and that is it, no additives.
I don't think you want to "run dry" a marine engine with fuel injection - I know with my MasterCraft boat the fuel pump is immersed in the gas tank and cooled by the fuel. MANY reports of MasterCraft owners running out of fuel and shortly thereafter having a fuel pump burn out. Stabil is easy, inexpensive, and it appears to work. WHY would anyone take a chance on this simple issue?
I use Stabie on my many stored items, and I get about 20 gallons of non ethanol gas to keep around for the emergency generator.
We have a couple marinas on the large lake I live on that still has that gas. (The Marinas are only open about 5 months a year!)
Its more expensive but worth it for items like the generator. I have to carry cans to the fuel dock so It kind of limits how much I buy. That also gets Stable added.
