Lumbar support possibly not working
Most of the controls of my seat work just fine, but I'm wondering if the lumbar support is working. When you adjust the lumbar support I can't feel anything happening inside the seat. Are you supposed to hear some sort of noise, maybe from a pump, when you adjust the seat. I presume you can adjust the support with the engine off. Because all the other controls on the seats work, is the lumbar support on a different fuse, and if so, can someone point me in the right direction (yes I know where to find the fuse box..).
Lumbar support users please advice
Received 2,046 Likes
St. Jude Donor '13
Since I usually change the lumbar when the engine is running, I don't hear anything. But it definitely moves, takes a second or two before I can tell the difference but there is a big range between fully inflated and fully deflated.
My lumbar support must be not working then, I can't feel the difference even after 20 seconds of pushing the button. On to the next question then, is there a separate fuse for the lumbar support and where can I find it.
