Techron
Old 10-29-2009, 07:08 PM
Keppah
Keppah's Avatar
Default Techron
Should techron be used in C6?
Old 10-29-2009, 07:23 PM
calemasters
calemasters's Avatar
Chevron gasoline with Techron is a Top Tier fuel. It is about all I use.
It you are asking about the Chevron Techron additive, is is recommended by GM, but is sold at GM dealers under the GM label GM "Fuel System Treatment PLUS".
xTooltipElement
Service Information 2005 Chevrolet Corvette | Corvette (VIN Y) Service Manual | Document ID: 2061828
#05-00-89-078B: GM Fuel System Treatment PLUS, Fuel Sending Unit Corrosion and Fuel System Deposits - (Feb 6, 2008)
Subject: GM Fuel System Treatment PLUS, Fuel Sending Unit Corrosion and Fuel System Deposits
Models: 2008 and Prior GM Passenger Cars and Trucks (including Saturn)
2008 and Prior HUMMER H2, H3
2005-2008 Saab 9-7X
This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 05-00-89-078A (Section 00 -- General Information).
Important : The GM Fuel System Treatment PLUS is not recommended for use with diesel fuel. The GM Fuel System Treatment PLUS is specially formulated for use in gasoline and/or E85 fuels.
GM Fuel System Treatment PLUS, P/N 88861011 (for U.S. ACDelco®, use 88861013) (in Canada, 88861012), is now available for use in gasoline engines.
Added Benefits and Uses
The PLUS portion of GM Fuel System Treatment PLUS is the addition of a filmer additive that, when used regularly, can protect fuel system sending units from the corrosive effects of certain sulfur contaminants found in some of today's gasoline.
Sulfur contamination can disrupt electrical continuity of certain fuel sending units and lead to erratic or false fuel gauge readings. With scheduled usage, GM Fuel System Treatment PLUS protects against the effects of harmful sulfurs in gasoline.
The Four Benefits
Just pour in one bottle of the GM Fuel System Treatment PLUS into the fuel tank when refueling around each oil change interval:
• Cleans -- Sulfur corrosion from fuel gauge sending units.
• Prevents -- Harmful sulfur components from attacking sensitive fuel system electronics.
• Protects -- By coating metallic surfaces of the fuel system.
• Removes -- Engine deposits left from use of poor quality fuels.
Parts Information
Part Number
Description
88861011 (for U.S. ACDelco, use 88861013)
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2009 General Motors Corporation. All rights reserved.
Swiftrider08
Swiftrider08's Avatar
Actually yes because it keeps deposits cleaned off the fuel sending unit that can cause the gas gauge to not read correctly. A bottle or two a year is a good thing.
Old 10-29-2009, 07:25 PM
06 C6 vert
06 C6 vert's Avatar
No not the additive in the bottle . I forgot why but have heard no. I have used it with good results in other cars however.
Old 10-29-2009, 07:31 PM
Keppah
Keppah's Avatar
Thanks for reply.Can't buy Chevron gas or Techron where I live(P.E.I.,Canada)I had bought some techron in Maine for 1997 Corvette I had and I have some left over.Putting 2007 Corvette away for winter and was going to fill with gas and add a bottle of Techron.Think it would be a good idea?
Old 10-29-2009, 07:40 PM
diverdan
Support Corvetteforum!
diverdan's Avatar
Occasional use of Techron, in addition to buying Chevron gas with it in it kept my fuel sending unit working when I had my C5Z. Like a lot of C5 owners, the gas gauge would quit working - a bottle or two of Techron later and it worked again.
Old 10-29-2009, 08:00 PM
VET4LES
VET4LES's Avatar
It's OK but in most cases not necessary. I haven't used any additive in many years and have not had any fuel related problems. I use Exxon fuel which is not a top tier fuel.
Old 10-29-2009, 08:07 PM
wolfdogs
wolfdogs's Avatar
Location: Stafford VA, home of our wolf den. No house break ins to date.
xTooltipElement
2005-2008 Saab 9-7X
The Four Benefits
Parts Information
Part Number
Description
smart man here. i drive way outta my way when i get low on gas to get Chevron...been doing in all my cars for years.
Old 10-29-2009, 08:14 PM
Dans C6
Dans C6's Avatar
I had to use it in the summer time due to the service fuel system warning on my dic. I put in 1 bottle so far and the problem did not come back. Gonna use this about twice a year to prevent it from happening again. Also would be a good idea to use it in your dd too.
Old 10-29-2009, 09:07 PM
need-for-speed
need-for-speed's Avatar
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
I've been applying elephant repellant in my front yard for years. I don't have elephants in my front yard. It is the best investment I have ever made.
Old 10-29-2009, 09:28 PM
carlrx7
carlrx7's Avatar
St. Jude Donor '08-'09
i have a texaco station 4 miles from the house, its actually the opposite way from everything i go to, but i go there instead of the other 10 stations on the way to work.
-carl
Old 10-29-2009, 09:31 PM
LMB-C6
LMB-C6's Avatar
It's just preventative maintenance. Back when fuel injection was introduced into the mainstream there were a lot more problems with deposits, etc. Don't really hear too much about it these days, probably because gas has a better additive package, especially the 'top tier' group.
As for putting it in right before storage - that's a waste of $. The stuff has to be run through the fuel system in order to do anything. If you just add it to the tank and not drive the vehicle it will do nothing.
Old 10-29-2009, 11:12 PM
Torch Ace
Torch Ace's Avatar
Where can you buy bottles of Techron if there's no Chevron stations around?
Old 10-29-2009, 11:16 PM
Schoolteacher
Schoolteacher's Avatar
me too!!!
Old 10-29-2009, 11:18 PM
obxchartercaptain
obxchartercaptain's Avatar
FL Events Coordinator
They also spread some in Washington, DC.....Elephants left last year. NOW, they need JACKASS Repellant.
Old 10-30-2009, 02:11 AM
ssv3
ssv3's Avatar
xTooltipElement
2005-2008 Saab 9-7X
The Four Benefits
Parts Information
Part Number
Description
Useful info that I wasn't aware of and Chevron with Techron is the only gas that prevents pinging on my car.
Old 10-30-2009, 08:10 AM
nwc6
nwc6's Avatar
Walmart has it, as does Autozone..Many autoparts stores have it, or just use the GM stuff. It does work. I had fuel gauge problems off and on in the C5, usually after winter storage. Fresh tank and a couple of bottles of techron got it going every time.
To Techron
Old 10-30-2009, 08:29 AM
AORoads
AORoads's Avatar
Received 2,481 Likes on 1,944 Posts
St. Jude Donor '15
"In honor of jpee"
just about every major auto parts store carries it as well as the discount stores and even Sam's and Costco.
Old 10-30-2009, 09:16 AM
6spdC6
6spdC6's Avatar
Location: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
I put a bottle in now and then in all our vechicles as part of my PM efforts. We do not have those gas stations around here so I normally get it at Wally World or Pep Boys. I had a lot of sticky gas gage problems with my 98 (C5) and it seems to work quite well!
Old 10-30-2009, 09:35 AM
inthehunt2
inthehunt2's Avatar
I can get a bottle of Techron at my local Napa/Murray's/O'Reiley's auto parts stores. F.Y.I.
Quick Reply: Techron
