Checking and Resetting Service Codes
Old 10-31-2009, 11:45 AM
Ahmer
Ahmer's Avatar
Default Checking and Resetting Service Codes
So today I get the check coolant level light... It's been a while since I have seen that one...rather annoying...
How do I check and reset service codes on this 2005 c6 MN6?
There is some kind of procedure and I forgot which buttons I have to hold down and for how long....
Old 10-31-2009, 11:50 AM
RadarP3C
RadarP3C's Avatar
The procedure has changed for the C6. You need to use a scanner.
talon90
Support Corvetteforum!
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The procedure you are remembering was from the C5. You could hold down the options button and press the fuel button four times to bring up a list of your DTC's.
That feature was disabled in the C6. The only way to read the codes is with a code reader. Find yourself a CAN BUS capable OBDII reader and you will be all set. No other user accessible way to get at the codes.
Old 10-31-2009, 11:51 AM
Zymurgy
Moderator
Zymurgy's Avatar
Received 15,067 Likes on 6,169 Posts
You cannot get the codes on the DIC like you could on the C5. You must get an OBDII reader, preferably one that is CAN enabled.
Old 10-31-2009, 11:53 AM
FortMorganAl
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Wal-Mart sometimes has an inexpensive one.
Old 10-31-2009, 12:23 PM
Zymurgy
Moderator
Zymurgy's Avatar
Check Amazon and eBay. You can pick up a very nice scanner for $50-$100 depending on features.
Old 10-31-2009, 02:03 PM
important
important's Avatar
Do you guys have an Advanced Auto Parts near you? They will check and reset your codes for free. No I dont work for them. I mentioned them on another thread as well 'cause theyre the closest auto parts store to me.
Old 10-16-2019, 12:46 PM
DrogonC6
4th Gear
DrogonC6's Avatar
Default Codes P0207
I changed the spark plugs and wires after getting the code P0207. I currently still have the CEL on and a code reader. Do I need to clear the code in order to know if I fixed the problem or should the CEL light go out on it’s own?
Old 10-16-2019, 03:49 PM
4SUMERZ
Race Car Tech
4SUMERZ's Avatar
Received 2,320 Likes on 1,664 Posts
Welcome to the forum. I know you are a new member, but why would you piggyback a 10 year old thread to ask your question?
Simply start a new thread, which will be relevant.
To answer your question, the code is for injector 7 control circuit, and you will need a code reader to clear the CEL
DrogonC6 (10-16-2019)
To Checking and Resetting Service Codes
Quick Reply: Checking and Resetting Service Codes
