Red light camera detector
Does anyone have or recommend a GPS Red Light Camera Dectector? I'm not looking for a radar detector with this built in, but something much less expensive.
St. Jude Donor '09-'10
Try this, a friend of mine claims it works great GPS Angel http://www.redlightcameradetectors.com/.
I use the Escort 9500ix
1. For the most part that Trapster app is useless. Guess where a speed trap is.... where ever I choose to sit for a minute.
2. As for the Red light camera detector..... I guess you are totally missing the point. Running red lights is the best way to get you or someone else killed, but good luck on finding a system to warn you so you actually stop for the light for a few seconds and potentially save a life.
Received 2,044 Likes
St. Jude Donor '13
I've never (knowingly) run a red light in my life. But too many municipalities are getting the cameras for revenue, most of the tickets around here are for an incomplete stop before making a right turn or because they shortened up the time of the yellow.
I bought the Cheetah (Google is your friend) unit, the little box instead of the miror system. It also warns of fixed speed cameras. Works very well mounted in my ash tray but I need to get the hardwire adapter.
I would like to know where they are so that I'm extra careful at that intersection. I think
mostly all of us have been driving and got caught midway in an intersection when the
light began to change. What is the tolerance of the cameras? If your rear end does not
completely clear the intersection when the light begans to change, will you still get
cited? Montgomery, Alabama has recently installed cameras all over the city and I am
on pins and needles when traveling there. I'm a very careful driver and try to obey all
traffic rules, but would still like to know where the cameras are.
Trapster + iPhone.
Music, phone, red light camera detection, internet radio, GPS Nav, all in one with bluetooth connection to my factory stereo. I sit in the car and everything is there. Can't beat it.
http://forums.corvetteforum.com/c6-c...adio-08-a.html
Escort 9500iX is the goods, its saved me from going through a yellow more than once...
Also, Escort makes a gps/redlight and speedtrap detector that runs in line with other radars, its about 160 bucks which is alot better than 400-500 for a new radar.
I dont' run red lights BUT, if you don't stop completly before making a right turn could earn a ticket as well! Isn't there something out there that is a defector or defuser for the license tag???
Most stop light enforcement and fixed speed cameras generally utilize ground loops in the pavement that measure speed/time/distance from RedFlex or American Traffic Systems - - -so your radar detector- regardless of brand- isn't likely to help.
A GPS-based "reminder" system as described can at least give you a heads-up where you've programmed alerts.
i never knowingly run red lights either. why is it so hard for people to understand that red light cameras are NOT about safety. i doubt many of the population run around buzzing through red lights for lack of care. it's usually accidental and the ticket is not a deterrent.
not to mention that sometimes it might be safest to run a light that is just about to turn red (such as if a car is bearing down on you to make a light, it's raining, you can't stop in time, etc.).
Their nonsense about safety is pure.
When there are cameras, you have more rear end collisions. If you have longer yellow lights, there are less of all collisions.
And that's before you try to address "due process." When these first came out, the courts were log-jammed. The solution? Remove the points, just apply the fine. That got people to stop challenging them.
It's about making money, pure and simple. Google "red light cameras" and "Lockheed-Martin" and you'll see a history of deceit and governments in on it. Increasing yellow light times solves the problem better.
If they really, really, really want camera, then install them and increase yellow light times. But they not only never do that, but Lockheed-Martin has been repeatedly caught "red handed" reducing the times.
This isn't about safety. Otherwise they'd always increase the yellow light times with the cameras. Truth.
