"Warning" about LG super-cooler radiator
Quick story: I have a 2009 C6 Z51 M6. I track my car alot and noticed oil temps up at the track. I wanted to get an oil cooler to keep temps in normal range at track. I looked around at options and talked to "guys" at LG motorsports. After talking with them I decided to get the radiator (1,125.00) instead of a simple aftermarket oil cooler because it would cool the water and has a oil cooler built in!! GREAT cooler water and oil in one unit!
Well after the install I noticed that I had sliightly lower water temps but HIGHER oil temps. I called today and this is the answer I got: Oh, yea...You will see higher oil temps because the oil cooler doesn't work that well...you have to leave your stock oil cooler on...don't use the oil cooler part of the radiator. WHAT! I wish they would tell me that before bought it I would have bought just a oil cooler from someone else and saved money...not to mention that I paid my tuner to remove the stock oil cooler and now I have to pay him to put it back on. I ask them if I could use them both (LG radiator/oil cooler with the stock oil cooler) and they said they are working on it but only for the Z06 not the Z51 LS3. They don't have an LS3 to use for fabrication of the parts needed to modify the system to work. Even there message on hold states the radiator will reduce water and oil temps........
Well I have my car heading back to tuner for the swap and now have to start looking for an oil cooler all over again. I talk to tuner and he stated in his conversations (he ordered it directly) they never told him to leave the stock cooler intact. I believe him because I was informed or misinformed the same.
I just wanted vent an let people know if your getting the radiator for oil cooling don't REMOVE the stock oil cooler!! It works for the water temps nicely but not the oil in new model vettes. I guess the cooler water will help the engine stay cooler but it does not help with oil cooling directly.....for now..
trapp
trapp
Moderator
Received 3,570 Likes
I'm told you can replace the Z51 cooler on the LS3 with the larger Z06 unit.
Former Vendor
I told you on the phone that we were working on a dual cooler replacement line kit. The Z06 cooler by it self helps a LOT. The Engine oil cooler by itself is not enough, nor is the stock oil cooler.
Customers that order the radiator will get a line kit that reuses the stock cooler in conjunction with the oil-water in the radiator.
I know you are upset, we have a solution, we are aware of the problem, you will not be left in the dark
He (tuner) stated he could order some stock oil lines and run the oil from the radiator to the stock oil cooler and then back to the engine!!!! This would run the oil through both systems and gain the benefit of both systems.. If this works then I'm a happy camper.
I posted only to let anyone know ordering the unit of this situation...I have alot of LG products on my car and very pleased with performance...this was just a communication issue..that would have let me make a more informed choice.
trapp
Former Vendor
Note up front... I am not doubting the OP!
If this is true, "Even there message on hold states the radiator will reduce water and oil temps........", then there is potentially false advertising involved. I certainly don't like dealing with vendors that bate you and then tell you that "we're working on it". That piece of information should be known at the start.
JMHO.
JMHO.
Everyone is allowed to make a mistake with a product. However, I don't believe the LG message was that they are owning up to it as their bad. It sounds more like LG doesn't understand why this is a big issue to someone, and they think that buyers shouldn't mind waiting for them to fix it.
LG, I don't think you can simply expect a customer to be happy because you are willing to fix it. I suggest you be professional. Admit it's your "bad". Say you're sorry and see if there is something LG can do to make it up to your customers until you fix YOUR bad.
Moderator
Meanwhile their message while on hold is that they have a system that cools both engine coolant and engine oil. They need to fix their message as it is false advertising. Again, JMHO.
trapp
trapp
